nuckollsr(at)cox.net Guest
Posted: Thu Mar 09, 2006 11:10 am Post subject: Marketing research question Annunciated Parameters List |
At 12:43 PM 3/9/2006 -0500, you wrote:
How about a simple "Master ON" reminder?
If you have active notification of low voltage (your primary
electrical system monitoring function), the it's already
jumping up and down right after the alternator is shut down
and/or the engine stops.
Posted: Thu Mar 09, 2006 11:13 am Post subject: Marketing research question Annunciated Parameters List |
At 11:27 AM 3/9/2006 -0600, you wrote:
<mark.steitle(at)austin.utexas.edu>
Bob,
This seems a good time to bring this up. My Chevy p/u has a cool little
"message center" that tells me that its time to change oil, or that the
cargo light is on, etc. It is about 1.5" square. I was wondering if it
would be possible to adapt this to experimental a/c use as a compact
annunciator? I don't have a clue as to how it works, but I thought that
it may be possible to get one from GM, or out of a wreck, and then
program a PIC to provide customized alerts for various things of
interest. It appears to use some sort of LED panel with yellow
lettering. So, does this sound plausible? Has anyone on the list done
this? Am I nuts?
Not at all. In fact, this is the wave of the future.
We keep watching it. At the present time it doesn't
fit our $time$ to market model.
Posted: Thu Mar 09, 2006 6:49 pm Post subject: Marketing research question Annunciated Parameters List |
At 04:01 PM 3/9/2006 -0500, you wrote:
Fuel Pres Lo
Engine (output from an engine monitor, to tell you to look at it to
see what problem it has found).
Another good one. I'll add it.
