Fuels
BobbyPaulk(at)comcast.net
PostPosted: Fri Jul 18, 2008 8:41 am    Post subject: Fuels Reply with quote
Since the Blog is tuned in to Fueling i have a question. (or two )
has anyone had problems using auto fuel with 10% Ethanol. Florida has decried that all fuel in the state WILL have 10% Ethanol by 2009. it is impossible to purchase fuel now that does not have Ethanol. i was using Amoco White ( now BP ) to prevent the orange stains but now even it has Ethanol.
the engine manual says it is permissible but i am concerned about corrosion in the aluminum tanks, deterioration of rubber hoses and internal rubber & plastics in fuel valves and pumps.
While we are on the subject of fuel has any one found a way to stop spraying it out the fuel tank vents when making a sharp turn with near full tanks. on a sod runway it makes a large brown circle ( Grass Kill ) when performing a 180 on the grass.
thanks
Bobby
601 XL
N131BP
Gig Giacona
PostPosted: Fri Jul 18, 2008 11:17 am    Post subject: Re: Fuels Reply with quote
Bobby,
You didn't mention which engine you are using. But as point out the engine isn't the only place Ethanol can cause a problem. It probably isn't the place it could cause the biggest problem.
W.R. "Gig" Giacona
601XL Under Construction
amyvega2005(at)earthlink.
PostPosted: Fri Jul 18, 2008 12:01 pm    Post subject: Fuels Reply with quote
I Ethanol mixes with water, why could you not pour Water into fuel with Ethanol and leach the alcohol out of the fuel? It goes with the thought that the way to check for Ethanol is to add water to fuel in a marked fuel beaker and check after time if the level of water increased, indicating Ethonal in Fuel.
Juan
Gig Giacona
PostPosted: Fri Jul 18, 2008 12:25 pm    Post subject: Re: Fuels Reply with quote
And what octane fuel do you have when you are finished with that science experiment?
Juan
W.R. "Gig" Giacona
Al Hays
PostPosted: Fri Jul 18, 2008 1:25 pm    Post subject: Fuels Reply with quote
Juan,
While you might be able to do that, I'm pretty sure you would wind up
an unacceptably low octane in the remaining fuel without the ethanol.
I've been using STA-BIL� gasoline stabilizer for gas engined home and
farm equipment and it seems to be effective. Now I see Marine
Formula STA-BIL� ethanol treatment being advertised and recommended
for all engines. I would probably be using that if I was flying with
autogas which might have ethanol in it. Neither of my projects is
going to be flying very soon but I intend to have them capable of
using regular pump autogas. One of my biggest worries is corrosion
in the thin aluminum gas tanks.
Al
N701GH and N5892H rexerved
On Jul 18, 2008, at 3:58 PM, Juan Vega wrote:
<amyvega2005(at)earthlink.net>
Juan
PostPosted: Fri Jul 18, 2008 2:53 pm    Post subject: Fuels Reply with quote
and does octane get impacted by leaching ethanol out, and if you buy 89 and the plane can run on 87 what is the impact, and is it worth bothering to take the ethanol out if the engine can take ethanol in the first place?
its an interesting question that opens a pandora's box
Juan
ronlee
PostPosted: Fri Jul 18, 2008 3:14 pm    Post subject: Re: Fuels Reply with quote
Don't forget you will lose ten percent of your fuel. That ups the price by $0.40 cents or so.
Ron Lee
Tucson, Arizona
Jeyoung65(at)aol.com
PostPosted: Fri Jul 18, 2008 6:02 pm    Post subject: Fuels Reply with quote
What will happen if the service station has water in it (most do) and the fuel has ethanol in it, how much water will the 10% ethanol absorb? Will this amount of water and ethanol cause a problem with engine operation?
Jerry of Ga
In a message dated 7/18/2008 4:02:13 P.M. Eastern Daylight Time, amyvega2005(at)earthlink.net writes:
[quote]--> Zenith-List message posted by: Juan Vega <amyvega2005(at)earthlink.net>
Juan
bryanmmartin
PostPosted: Sat Jul 19, 2008 12:24 pm    Post subject: Fuels Reply with quote
A little bit of water will dissolve in the gasohol. A little bit more will cause the water/alcohol mixture to settle out, leaving a lower octane gasoline floating above it. I don't know exactly how much water it takes to initiate the separation but I do know that 10 percent water mixed with E10 will do it. This is the standard test for ethanol in gasoline. I suspect it takes a whole lot less than 10% water to cause the separation.
So any water in the station's tank will either end up in your gas tank or it will settle out on the bottom of their tank along with the alcohol and you will be filling up with low octane gas. In either case, it won't do good things to your engine.
On Jul 18, 2008, at 9:58 PM, Jeyoung65(at)aol.com (Jeyoung65(at)aol.com) wrote:
[quote] What will happen if the service station has water in it (most do) and the fuel has ethanol in it, how much water will the 10% ethanol absorb? Will this amount of water and ethanol cause a problem with engine operation?
Jerry of Ga
In a message dated 7/18/2008 4:02:13 P.M. Eastern Daylight Time, amyvega2005(at)earthlink.net (amyvega2005(at)earthlink.net) writes:
[quote] [quote][b]
Bryan Martin
do not archive.
daveaustin2(at)primus.ca
PostPosted: Sat Jul 19, 2008 3:04 pm    Post subject: Fuels Reply with quote
It's interesting that we've been advised by someone in the industry that the wholesalers add the ethanol to the truckloads. It isn't added earlier due to the water absorbsion problem. So guess what happens if there is water in the truck or in the retailers' tanks!
Then when you go up to 8000 ft and the fuel in your tank gets colder that water can separate and collect at the bottom of your fuel tank.
I don't want to go there.
Dave Austin 601HDS - 912, Spitfire Mk VIII
PostPosted: Sun Jul 20, 2008 7:48 am    Post subject: Fuels Reply with quote
Thanks for the information. Not what I wanted to hear, BUT is what I was afraid of. Jerry of Ga
In a message dated 7/19/2008 4:25:34 P.M. Eastern Daylight Time, bryanmmartin(at)comcast.net writes:
Jerry of Ga
--> Zenith-List message posted by: Juan Vega <amyvega2005(at)earthlink.net (amyvega2005(at)earthlink.net)>
Juan
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
do not archive.
f="http://www.matronics.com/Navigator?Zenith-List">http://www.matronics.com/Navigator?Zenith-List
.matronics.com/">http://forums.matronics.com
://www.matronics.com/contribution">http://www.matronics.com/contribution
Get fantasy football with free live scoring. Sign up for FanHouse Fantasy Football today.
