Main Landing Gear Fairing Bolt Failure
billderou(at)yahoo.com
PostPosted: Sat Jul 19, 2008 12:51 pm    Post subject: Main Landing Gear Fairing Bolt Failure Reply with quote
I landed approximately a dozen times on a long, grass strip in the Idaho wilderness and found the AN4-6 bolt shown on page 46-5 figure 2 sheared at the cotter pin. This is the AN4 that pokes out of the large axel nut to hold the fairing standoff. The port side failed but the starboard MLG fairing could be wiggled and would soon fail.
The strip is pocked with small mounds much like a polo field before the divits are replaced. There were no holes, nor did I hit anything, nor did I land hard. The fiberglass fairing is still pristine. What caused the problem is the fairing jiggling up and down during the roll out.
Tearing the landing gear down for inspection revealed that the current design will not work over time. I believe the failure begins at the 3 U-1008 spacers shown on page 46-4 figure 4. When the fairing bounces about these spacers gall the U-1010L plate and loosen the inboard side of the fairing. Once the inboard side of the fairing begins to move around it has a 5 inch lever arm (U-1004B) from the outboard fairing attachment point that works the AN4 bolt and will shear it at the cotter pin hole. Looking at the sheared bolt endwise the structural area is very small after the cotter hole is drilled and the thread depths are subtracted.
Two items need to be redesigned. The three bolts thru U-1010L cannot be tightened because the tension simply crushes the aluminum spacers. The spacers need to be steel and the joint tightened. I don't have a lathe but do have lots of 4130 tubing .5" OD by .375 ID. I cleaned the inside of the tube with a .375" ream and pressed the aluminum spacer inside. Added a washer between the spacer and the U-1010L and tightened it properly. Now it is much stiffer.
Beefing up the AN4 at the axel nut required much more work. If you only have a hammer then you use a hammer to fix all problems. I created a weldment with a TIG welder but a lathe is the better tool. I used the same steel .5"OD by .375"ID tubing and constructed a standoff with an AN5 stud on one end and an AN4 nut on the other. Drilled out the axel nut for the AN5 and placed the AN5 nut on the inside of the axel nut. Make sure you have clearance when the big cotter pin is inserted thru the axel nut. I am sure there are many more clever approaches but this will work.
BTW there were several flight test engineers at our camp that encouraged me to fly home from Idaho with one MLG fairing on and the other off. This would be more convenient as my RV-10 was stuffed full of camping equipment and there was no room for another MLG fairing. I duct taped the leg fairings in place and took off. They were right. At cruise the cost was 8 mph and 1/4 bubble of rudder. No handling difference.
Bill DeRouchey
N939SB, flying
Tim Olson
PostPosted: Sat Jul 19, 2008 2:30 pm    Post subject: Main Landing Gear Fairing Bolt Failure Reply with quote
Bill,
Were you already using improved axle extensions? These
are what we came up with a couple years ago to fix breakage
at that point.
http://www.myrv10.com/N104CD/upgrades/20070118/index.html
If not, that's a pretty easy way to strengthen that point,
as that stem actually doesn't have enough base to prevent
the hex rod from rocking back and forth.
Did you actually see deformation of those 3 spacers?
From what it sounds like at first glance, you may be going
about it the hard way to fix the problem, but I'd like to hear
more of what damaged parts you found OTHER than the bolt
stem.
subtracted.
will work.
Bill DeRouchey
N939SB, flying
PostPosted: Sat Jul 19, 2008 6:19 pm    Post subject: Main Landing Gear Fairing Bolt Failure Reply with quote
Hi Tim-
I remember the list addressing the AN4-6 bolt issue but I had already mounted my wheels and did not want to back track. Maybe I should have in retrospec.
My extensions were Vans stock with no modifications. The U-1008 spacers were galled at the contact with U-1010L and had dug in approx 1/64". All three spacers/plate showed the same wear and the "wiggle" produced at the forward point of the fairing was very noticable. It was approximately 3/4" top to bottom and 1/2" left to right. Imagine the U-1010L plate mounted on 3 weak standoffs and the little play required to move the forward point of the fairing. Of course, this was with the small shoulder spacer from Vans on the outboard side.
The modification of the axel nut standoff as in your drawing should work very well but it is only half of the problem. It would address and solve wiggle on the outboard fairing attach point but is carrying load that should be disipated by the U-1010L plate. By not shifting load to the U-1010L the big countersunk 1/4-28 screw and the fiberglass at the outboard end of the standoff must be handling a lot of shock when the tire hits a bump.
If anyone flying has wiggle in their MLG fairings I believe it can be traced to galling between U-1008 and U-1010L. Omitting a steel washer created the galling but the inability to properly torque the three bolts is also problematic. I initially torqued the three bolts with a thin washer between the aluminum pieces and watched the spacer puff out. After adding an outer steel sheath and a thin washer to fill-in the indentation of U-1010L the plate torques to a solid mount for the fairing. The difference in U-1010L stiffness between the before and after is huge.
Bill DeRouchey
N939SB, flying
--- On Sat, 7/19/08, Tim Olson <Tim(at)MyRV10.com> wrote:
[quote]From: Tim Olson <Tim(at)MyRV10.com>
Subject: Re: Main Landing Gear Fairing Bolt Failure
Date: Saturday, July 19, 2008, 3:24 PM
[quote]--> RV10-List message posted by: Tim Olson <Tim(at)myrv10.com> Bill, Were you already using improved axle extensions? These are what we came up with a couple years ago to fix breakage at that point. http://www.myrv10.com/N104CD/upgrades/20070118/index.html If not, that's a pretty easy way to strengthen that point, as that stem actually doesn't have enough base to prevent the hex rod from rocking back and forth. Did you actually see deformation of those 3 spacers? From what it sounds like at first glance, you may be going about it the hard way to fix the problem, but I'd like to hear more of what damaged parts you found OTHER than the bolt stem. Tim Tim Olson - RV-10 N104CD - Flying do not archive Bill DeRouchey wrote: > I landed approximately a dozen times on a long, grass strip in the Idaho > wilderness and found the AN4-6 bolt shown on page 46-5 figure 2 sheared > at the cotter pin. This is the AN4 that pokes out of the large axel nut > to hold the fairing standoff. The port side failed but the starboard MLG > fairing could be wiggled and would soon fail. > > > > The strip is pocked with small mounds much like a polo field before the > divits are replaced. There were no holes, nor did I hit anything, nor > did I land hard. The fiberglass fairing is still pristine. What caused > the problem is the fairing jiggling up and down during the roll out. > > > > Tearing the landing gear down for inspection revealed that the current > design will not work over time. I believe the failure begins at the 3 > U-1008 spacers shown on page 46-4 figure 4. When the fairing bounces > about these spacers gall the U-1010L plate and loosen the inboard side > of the fairing. Once the inboard side of the fairing begins to move > around it has a 5 inch lever arm (U-1004B) from the outboard fairing > attachment point that works the AN4 bolt and will shear it at the cotter > pin hole. Looking at the sheared bolt endwise the structural area is > very small after the cotter hole is drilled and the thread depths are > subtracted. > > > > Two items need to be redesigned. The three bolts thru U-1010L cannot be > tightened because the tension simply crushes the aluminum spacers. The > spacers need to be steel and the joint tightened. I don't have a lathe > but do have lots of 4130 tubing .5" OD by .375 ID. I cleaned the inside > of the tube with a .375" ream and pressed the aluminum spacer inside. > Added a washer between the spacer and the U-1010L and tightened it > properly. Now it is much stiffer. > > > > Beefing up the AN4 at the axel nut required much more work. If you only > have a hammer then you use a hammer to fix all problems. I created a > weldment with a TIG welder but a lathe is the better tool. I used the > same steel .5"OD by .375"ID tubing and constructed a standoff with an > AN5 stud on one end and an AN4 nut on the other. Drilled out the axel > nut for the AN5 and placed the AN5 nut on the inside of the axel nut. > Make sure you have clearance when the big cotter pin is inserted thru > the axel nut. I am sure there are many more clever approaches but this > will work. > > > > BTW there were several flight test engineers at our camp that encouraged > me to fly home from Idaho with one MLG fairing on and the other off. > This would be more convenient as my RV-10 was stuffed full of camping > equipment and there was no room for another MLG fairing. I duct taped > the leg fairings in place and took off. They were right. At cruise the > cost was 8 mph and 1/4 bubble of rudder. No handling difference. > > > > Bill DeRouchey > > N939SB, flying > [quote][b]
Tim Olson
PostPosted: Sat Jul 19, 2008 7:19 pm    Post subject: Main Landing Gear Fairing Bolt Failure Reply with quote
Hi again Bill,
One more followup... you said "It was approximately 3/4" top to bottom
and 1/2" left to right."
I want to make sure I'm understanding. Are you saying that if you
grab the top of that fairing mounting plate (the big swiss cheese
bent thick aluminum metal plate) that you can rock it back and forth
pulling in/out on it if you're sitting facing the side of the wheel
grabbing it by the top, and if you grabbed it by the aft end of that
plate you could pull it 1/2" in and out? As in, that whole plate
gets wobbly?
I ask because so far, mine is very solid with no slop, at 360 approx
hours. I just mounted those flex brake lines to that plate
not long ago so I recently had it apart, and it's really tight.
I've had the axle extension now for probably the last 2 years
or so though, so I'm wondering if maybe yours loosened over time
maybe partly due to the fact that you hadn't been using the extensions.
That would be a possibility I'd think. Let me know if I'm
misunderstanding how it was loose though.
I do think that the outer end of the fairing mount, where it attaches
to the extension, will naturally have to support quite a bit of
bumping up and down. Even if that plate were solid (and by all means,
making or keeping it solid is a great thing), I think that 1/4-28
stainless screw needs to hold that fairing pretty solidly, as there
is going to be quite a bit of torque from the axle extension to
the axle nut trying to snap that bolt. I know my hex rod, even
after 6-12 months, had rounded the corners over rocking on that
metal washer....so yeah, that bolt in the standard design is
definitely a fracture point waiting to happen. Anything you can
do...any of the various axle extensions that were created, should
help make that bolt snapping much much less of an issue. I personally
think they should be standard parts with the kits, given the size
of the wheel fairings we carry around....and the number of
broken extensions we've seen. I know there are over a half-dozen
or more.
Hi Tim-
retrospec.
tire hits a bump.
after is huge.
Bill DeRouchey
N939SB, flying
Bill,
at that point.
stem.
> subtracted.
inside
with an
> will work.
> Bill DeRouchey
> N939SB, flying
PostPosted: Sun Jul 20, 2008 8:19 am    Post subject: Main Landing Gear Fairing Bolt Failure Reply with quote
Hi again Tim - (its all good discussion)
The wobble measurements of 3/4" vertical and 1/2" lateral was the distance my hand was moving when testing the fairing security during my pre-flight. My hand was on the forward tip of the fairing. So it had an approx 18" of lever arm on the U-1010L plate. Working with just the plate: if you tighten the plate then back off each bolt to create a 1/64" opening it would be equilivant to the plate wiggle that I observed. Thinking about it more it was probably closer to 1/32".
All forces on the fairing need to be transfered back into the axel and the mount acts as a system with attach points at the fairing outboard and inboard. When a weak point develops it "leans" on the other side to accelerate wear at that point. Then they go back and forth destroying each other very quickly.
The standard axel end standoff orbiting about the AN4-6 bolt is the weak point outboard and the U-1008 to U-1010 joint galling is the weak point inboard. Yesterday, I thought the galling was the original sin that broke the AN4-6 bolt but your information indicates that the standoff is the major problem since your U-1010 plate is still secure. If you solve the problem on one side it reduces the forces on the other. It would not surprise me that if one mounted the U-1010 plate as I suggested earlier with a washer and steel spacers the AN4-6 bolt would not break for a thousand plus hours.
If you were smarter than me and deviated from the plans slipping a thin washer between the U-1008 and the U-1010 then you have a good 90% solution that will probably last forever. If not, the joint absolutely will gall and loosen over time. Question is how much time?
I think every weak point needs fixing to keep a system failure from occuring.
Devise any standoff with a large OD that will not orbit and no cotter key through the bolt
Add a washer between the U-1008 and U-1010
Replace the U-1008 with steel spacers and torque properly
Its all about minimizing problems over long service times. Nothing really needs to be fixed until the fairing begins to wiggle. Just check it on your pre-flight.
Bill DeRouchey
N939SB, flying
Date: Saturday, July 19, 2008, 8:14 PM
[quote]--> RV10-List message posted by: Tim Olson <Tim(at)myrv10.com> Hi again Bill, One more followup... you said "It was approximately 3/4" top to bottom and 1/2" left to right." I want to make sure I'm understanding. Are you saying that if you grab the top of that fairing mounting plate (the big swiss cheese bent thick aluminum metal plate) that you can rock it back and forth pulling in/out on it if you're sitting facing the side of the wheel grabbing it by the top, and if you grabbed it by the aft end of that plate you could pull it 1/2" in and out? As in, that whole plate gets wobbly? I ask because so far, mine is very solid with no slop, at 360 approx hours. I just mounted those flex brake lines to that plate not long ago so I recently had it apart, and it's really tight. I've had the axle extension now for probably the last 2 years or so though, so I'm wondering if maybe yours loosened over time maybe partly due to the fact that you hadn't been using the extensions. That would be a possibility I'd think. Let me know if I'm misunderstanding how it was loose though. I do think that the outer end of the fairing mount, where it attaches to the extension, will naturally have to support quite a bit of bumping up and down. Even if that plate were solid (and by all means, making or keeping it solid is a great thing), I think that 1/4-28 stainless screw needs to hold that fairing pretty solidly, as there is going to be quite a bit of torque from the axle extension to the axle nut trying to snap that bolt. I know my hex rod, even after 6-12 months, had rounded the corners over rocking on that metal washer....so yeah, that bolt in the standard design is definitely a fracture point waiting to happen. Anything you can do...any of the various axle extensions that were created, should help make that bolt snapping much much less of an issue. I personally think they should be standard parts with the kits, given the size of the wheel fairings we carry around....and the number of broken extensions we've seen. I know there are over a half-dozen or more. Tim Olson - RV-10 N104CD - Flying do not archive Bill DeRouchey wrote: > Hi Tim- > > I remember the list addressing the AN4-6 bolt issue but I had already > mounted my wheels and did not want to back track. Maybe I should have in > retrospec. > > > > My extensions were Vans stock with no modifications. The U-1008 spacers > were galled at the contact with U-1010L and had dug in approx 1/64". All > three spacers/plate showed the same wear and the "wiggle" produced at > the forward point of the fairing was very noticable. It was > approximately 3/4" top to bottom and 1/2" left to right. Imagine the > U-1010L plate mounted on 3 weak standoffs and the little play required > to move the forward point of the fairing. Of course, this was with the > small shoulder spacer from Vans on the outboard side. > > > > The modification of the axel nut standoff as in your drawing should work > very well but it is only half of the problem. It would address and solve > wiggle on the outboard fairing attach point but is carrying load that > should be disipated by the U-1010L plate. By not shifting load to the > U-1010L the big countersunk 1/4-28 screw and the fiberglass at the > outboard end of the standoff must be handling a lot of shock when the > tire hits a bump. > > > > If anyone flying has wiggle in their MLG fairings I believe it can be > traced to galling between U-1008 and U-1010L. Omitting a steel washer > created the galling but the inability to properly torque the three bolts > is also problematic. I initially torqued the three bolts with a thin > washer between the aluminum pieces and watched the spacer puff out. > After adding an outer steel sheath and a thin washer to fill-in the > indentation of U-1010L the plate torques to a solid mount for the > fairing. The difference in U-1010L stiffness between the before and > after is huge. > > > > Bill DeRouchey > > N939SB, flying > > > > --- On *Sat, 7/19/08, Tim Olson /<Tim(at)MyRV10.com>/* wrote: > > From: Tim Olson <Tim(at)MyRV10.com> > Subject: Re: Main Landing Gear Fairing Bolt Failure > To: rv10-list(at)matronics.com > Date: Saturday, July 19, 2008, 3:24 PM > > --> RV10-List message posted by: Tim Olson <Tim(at)myrv10.com> > > > > Bill, > > Were you already using improved axle extensions? These > are what we came up with a couple years ago to fix breakage > at that point. > http://www.myrv10.com/N104CD/upgrades/20070118/index.html > If not, that's a pretty easy way to strengthen that point, > as that stem actually doesn't have enough base to prevent > the hex rod from rocking back and forth. > > Did you actually see deformation of those 3 spacers? > > From what it sounds like at first glance, you may be going > about it the hard way to fix the problem, but I'd like to hear > more of what damaged parts you found OTHER than the bolt > stem. > > Tim > Tim Olson - RV-10 N104CD - Flying > do not archive > > Bill DeRouchey wrote: > > I landed approximately a dozen times on a long, grass strip in the Idaho > > wilderness and found the AN4-6 bolt shown on page 46-5 figure 2 sheared > > at the cotter pin. This is the AN4 that pokes out of the large axel nut > > to hold the fairing standoff. The port side failed but the starboard MLG > > fairing could be wiggled and would soon fail. > > > > > > > > The strip is pocked with small mounds much like a polo field before the > > divits are replaced. There were no holes, nor did I hit anything, nor > > did I land hard. The fiberglass fairing is still pristine. What caused > > the problem is the fairing jiggling up and down during the roll out. > > > > > > > > Tearing the landing gear down for inspection revealed that the current > > design will not work over time. I believe the failure begins at the 3 > > U-1008 spacers shown on page 46-4 figure 4. When the fairing bounces > > about these spacers gall the U-1010L plate and loosen the inboard side > > of the fairing. Once the inboard side of the fairing begins to move > > around it has a 5 inch lever arm (U-1004B) from the outboard fairing > > attachment point that works the AN4 bolt and will shear it at the cotter > > pin hole. Looking at the sheared bolt endwise the structural area is > > very small after the cotter hole is drilled and the thread depths are > > subtracted. > > > > > > > > Two items need to be redesigned. The three bolts thru U-1010L cannot be > > tightened because the tension simply crushes the aluminum spacers. The > > spacers need to be steel and the joint tightened. I don't have a lathe > > > but do have lots of 4130 tubing .5" OD by .375 ID. I cleaned the > inside > > of the tube with a .375" ream and pressed the aluminum spacer inside. > > > Added a washer between the spacer and the U-1010L and tightened it > > properly. Now it is much stiffer. > > > > > > > > Beefing up the AN4 at the axel nut required much more work. If you only > > have a hammer then you use a hammer to fix all problems. I created a > > weldment with a TIG welder but a lathe is the better tool. I used the > > same steel .5"OD by .375"ID tubing and constructed a standoff > with an > > AN5 stud on one end and an AN4 nut on the other. Drilled out the axel > > nut for the AN5 and placed the AN5 nut on the inside of the axel nut. > > Make sure you have clearance when the big cotter pin is inserted thru > > the axel nut. I am sure there are many more clever approaches but this > > will work. > > > > > > > > BTW there were several flight test engineers at our camp that encouraged > > me to fly home from Idaho with one MLG fairing on and the other off. > > This would be more convenient as my RV-10 was stuffed full of camping > > equipment and there was no room for another MLG fairing. I duct taped > > the leg fairings in place and took off. They were right. At cruise the > > cost was 8 mph and 1/4 bubble of rudder. No handling difference. > > > > > > > > Bill DeRouchey > > > > N939SB, flying > > > > > * > > > * > [quote][b]
Tim Olson
PostPosted: Sun Jul 20, 2008 10:09 am    Post subject: Main Landing Gear Fairing Bolt Failure Reply with quote
I agree with your comments Bill. I think in an ideal world, if you
fixed it on both sides, you'd never have any issue at all. If
you fix it on either side, you probably lessen your chances of
having problems greatly. If you leave it as-is on the plans,
you probably COULD go a long time, but eventually you'll have
some wear or weakening and when you land on grass you'll have
those original axle extensions break.
For me, I'll just monitor those spacers for now then, because
I'm not seeing that with the heavier-duty extensions that
there's as much flex going on to gall the parts. But, I
may slip in a thin washer next time I'm in that area, to
help prevent wear on the metal plate.
Great that you brought it up and clarified it. Certainly if
there were that 3/4 and 1/2" movement on the metal plate, that
would be really severe....at least those measurements were
at the fairing tips. Still not good, but now I see why the
number was larger than I expected.
So far it looks to me like the 2 most "faulty" or in-need-of-fix
areas on the plane are probably those axle extensions and spacers
on the mains that we're talking about, and the spacer system up
on that nosewheel. Other than that, the plane is adding up
lots of good hours with no major issues.
occuring.
Bill DeRouchey
N939SB, flying
Hi again Bill,
bottom
gets wobbly?
or more.
> Hi Tim-
> retrospec.
All
produced at
the
> tire hits a bump.
> after is huge.
> Bill DeRouchey
> N939SB, flying
> Bill,
> at that point.
> stem.
> Tim
> do not archive
the Idaho
sheared
axel nut
starboard MLG
before the
nor
caused
out.
current
the 3
bounces
side
move
fairing
cotter
is
are
> > subtracted.
cannot be
spacers. The
have a lathe
the
> inside
spacer inside.
it
you only
created a
the
standoff
> with an
axel
nut.
thru
this
> > will work.
encouraged
off.
camping
taped
cruise the
> > Bill DeRouchey
> > N939SB, flying
