gmcjetpilot(at)yahoo.com Guest
Posted: Fri Mar 10, 2006 3:26 am Post subject: Marketing research (roll your own annunciator panel) |
http://img30.imageshack.us/img30/1124/annunciatorpanel0rx.jpg
Here is a thread on how to make your own annunciator:
http://www.vansairforce.com/community/showthread.php?t=5197&page=1&pp=10&highlight=annunciator
Here is vx-aviation annunciator controller:
http://www.vx-aviation.com/page_2.html#IL-4A,%20IL-12A_more
Vx-aviation is coming out with an annunciator panel which looks like:
http://vx-aviation.com/photos/AN-4A_product.jpg
The annunciator lights are modular so you can build up 4 or 12.
At most I would have 3 annunciators:
Volts, Oil P, Boost Pump (if I had discrete lights)
I don't personally need discrete annunciators. I have a GRT EIS 4000,
a brilliant piece of equipment that monitors everything. When I say
everything I mean everything. The EIS-4000 has a master caution
warning light that warns if there is an exceedance (Hi/Lo/Rate of change)
for every parameter of ALL aircraft system's:
(volt's/current/pressure's/flow's/level's/temp's/rpm/map)
This is the warning function works like this (look at bottom):
http://www.grtavionics.com/images/M46_Fig1B.GIF
http://www.grtavionics.com/images/M46_Fig1A.GIF
The only discrete lights the EIS4000 does not annunciate for me
at this time is the alternator's own internal warning light (internal VR).
I used (yellow) for caution.
The only other system light I considered was Fuel Pump - ON (blue).
If I did not have the GRT EIS4000, I would add Oil Pressure (red).
As far as colors this is what Boeing uses.
Red - Warning - requires urgent action to avoid damage
Yellow - Caution - may require action but not as urgent
White - Advisory - system Info (not flight critical / maintenance)
Blue - Normal system state
Cheers George
Bring photos to life! New PhotoMail makes sharing a breeze.
