mrspudandcompany(at)veriz Guest
nuckolls.bob(at)cox.net Guest
Posted: Sun Jul 20, 2008 9:47 am Post subject: IR to ER alternator mod |
At 12:21 PM 7/19/2008 -0400, you wrote:
I'm not in a position to comb it for details but the
concept is solid and if the writer has made no errors,
it will work as advertised. I'm not hard over on removing
the built in regulators. As a rule, these are perfectly
satisfactory pieces of electronics. So if your thinking
runs more in line with Plane Power's approach to adapting
the IR alternator (and as suggested in the earlier mod
article) I sure wouldn't have any heartburn over it.
( -Thomas Paine 1776- )
gmcjetpilot
Posted: Sun Jul 20, 2008 1:44 pm Post subject: IR to ER alternator mod |
Roger: I have seen that back a few years ago and
studied it. I even talked by email to the Gent.
He does a great job of documenting with text and pics
the mod and explaining background info.
I particularly like the "A" version where you control the
field on the ground side. The mod is clearly very very
easy. The "B" type mod is more involved and I really
think the brush holder modification looks a little delicate,
but if done carefully it should be reliable.
The "A" mod is a thing of beauty, but the down side of
the "A" controlled field is the following:
If you short out your field wire it will go full tilt boogie.
Of course protecting the field wire with insulation and
proper routing support is not hard. You can make it
almost short proof and reliable. The second drawback
is "A" type external voltage regulators are much less
common. I found a couple that are in current
production. However my favorite external VR is the "B"
type Transpo V1200, fully digital OV and fault protected
voltage regulator for about $75. (avail by order at most
commercial auto elect shops). It is made for heavy duty
Ford vehicles like an ambulance.
http://www.aeroelectric.com/Mfgr_Data/Regulators/Transpo/V1200_Transpo.pdf
Unfortunately the V1200 is a "B" type controller varies
the positive side of the field to control the alternator's
output.
If you want an "A" type, one model off the top of my
head os for a SEADOO (yes SEADOO):
Voltage Set Point: 14.5 V Regulation: A-Circuit
Transpo #: 4229-124
SEADOO #: 27800-1241, 27800-1554
http://www.transpo.de/Catalog/Images/4229124.jpg
There are other "A" type but like this one and you could
utilize the automotive/sealed connectors.
Good luck, personally the internal regulator has thermal
protection and an IC micro processor which offers way
more protection. Also there are no DIY home-brew
solder joints. Keep the internal regulator, supply cooling
air to it, never turn the alternator ON/OFF while the
engine is running (ie turn it on before start and off after
shutdown as it was designed) and your chance of
problems will be very low. (PS, no crow bar)
There are stock ND's that have well over 1000 hours on them.
I do recommend you proactively changing brushes at
750 hours +/- 250 hours. They are cheap and easy to replace.
Low humidity at altitude is hard on the brushes verses car use.
Also we tend to run more avg output than a car in a hot cowl
on a shaking engine, more severe than most cars.
Also don't buy lousy rebuilds and lousy clone alternators.
There are good vendors and bad ones. If you go with
PlanePower or even Van (now they are using a better
aftermarket vendor) you should be fine.
If you are doing all this because you are worried that your
internal regulator will go insane and melt your electical
system down, you are worrying too much. That story is
way over blown and very rare. In the cases where damage was
done the pilot did a few things to make it happen. Most
failures of ND type alternator are usually not OV but
they just stop working. When they do lose stable voltage
regulation they generally top out in the 16-17 volt range. Most
modern avionics can work on 10-30 volts all day long.
In the event of say an unstable regulator, lower RPM,
increase load (landing lights) and ideally you have a
pull-able CB in the panel for you B-lead, pull CB, reduce
elect load & land. No fear no dark and stormy night.
Also IR gives you a LO/Hi volt and fault warning light.
Cheers George
>From: "ROGER & JEAN CURTIS" <mrspudandcompany(at)verizon.net>
| Quote: | Subject: IR to ER alternator mod
Here is another IR to ER alternator mod.
I would appreciate your evaluation and comments as I may use this
>method.
http://www.falco.co.nz/index.php?option=com_content&view=article&id=86&Itemid=72
gmcjetpilot
Posted: Sun Jul 20, 2008 3:25 pm Post subject: IR to ER alternator mod |
I forgot about Chrysler, who do make some "A" type regulators. This one has adjustable voltage.
Voltage Set Point: 14.3V; Regulation: A-Circuit
»» Special Heavy Duty Version of C8312
»» Solid State Circuit
»» Superior Loading
»» Adjustable Voltage
»» For 7A Rotors
FOR USE ON: Chrysler Products
Transpo part # C8312
CHRYSLER Part #'s (x-reference)
3 438 150
3 755 850
3 755 960
3 874 520
4 091 050
4 111 990
Of course not many external regulators include any over type relay. I recommend power the regulator through one of these (I like it better than the Crow Bar short CB short method.)
http://www.periheliondesign.com/lovm.htm
All the best. George
Posted: Sun Jul 20, 2008 3:27 pm Post subject: IR to ER alternator mod |
At 02:39 PM 7/20/2008 -0700, you wrote:
| Quote: | Roger: I have seen that back a few years ago and
<snip>
Over blown? Is that between humongous and gargantuan
or just under bodacious . . . I forget.
But even your words "very rare" says the risk is
not zero.
| Quote: | In the cases where damage was
George, go away. You have ZERO evidence of
that and your accusation is uncalled for.
The evidence contrary to that statement is
solid and inarguable which makes your statement
tantamount to calling goodly numbers of folks
liars.
| Quote: | Most
Maybe . . . but again, are you ready to offer
100% coverage insurance for the ones that are not
"generally" topping out at 17V?
| Quote: | Most
But batteries don't. Lights don't. Contactors don't
and how many OBAM aircraft are fitted only with
"modern" avionics . . . and exactly when does "modern"
kick in? 1985? 1996?
Okay, a fully fielded ND puts out full rated current
at about 4500 shaft RPM. When running at cruise
(2500 on engine) the alternator is spinning at about
4x that. So if we want to get the alternator to be
current limited to say 20A, we need to get it down to
about 1500 RPM which puts the engine at less than
idle. What kind of emergency operations procedure
is that?
But assuming that you can pull a b-lead breaker
and bring the power back up, the alternator self-
destructs.
Your advice is horse-hockey by the bucket-full
George. Go away.
| Quote: | Also IR gives you a LO/Hi volt and fault warning light.
Which is only a warning light as far as anyone can
deduce from the lack of schematics to substantiate
any claims to the contrary. It does nothing to
actively shut down an alternator being driven by
a failed regulator.
. . . and oh yes, if the designers included ov warning
in their product, could it be that they also believe
the risk for their product to malfunction is not zero?
. . . or do you think they included that feature just
to placate me?
Go away George. I will not have you trolling this
List for acolytes in the Cult of the Infallible ND.
Go start your own List.
steve(at)tomasara.com Guest
Posted: Mon Jul 21, 2008 9:18 am Post subject: IR to ER alternator mod |
Bob, Eric, George, JetPilot and the rest of the list:
From the perspective of someone who has been following the list for a
while and who is not as ignorant as most of things electrical nor of
lists supporting the free exchange of ideas and, perhaps most important,
someone who is not "tribal" in the least, I respectfully ask that Eric,
George, JetPilot NOT go away.
I don't have to agree with different viewpoints to appreciate them. As
much as we all strive for simple ideas and imagine that correct
application of logic will always result in absolute truths, the reality
is that there is much variation in our foundation goals, premises etc.
that have a great affect on our individual conclusions of what is right
for each of us. I, for one, think this list would be greatly enhanced
if there was less defensive posturing, bile etc. Responses to ideas
found to be objectionable could be concisely communicated as simply as
"regarding the idea that ... suffice to say that although there are
proponents of this approach I strongly disagree with it for reasons that
are well documented in past posts. Please do your homework on this idea
and the alternatives before committing to an approach".
The 'I'm still right and you're still wrong and since you still don't
agree with me let me explain it to you louder (or longer...)', which, by
my reading, has been evident in both camps of the great debate seems to
me to be not just disrespectful to the involved parties but also to the
list-reading public in general.
Best wishes to all,
Steve Stearns
Boulder/Longmont, Colorado
CSA,EAA,IAC,AOPA,PE,ARRL,BARC (but ignorant none-the-less)
Restoring (since 1/07): N45FC O235 Longeze Cothern/Friling CF1 (~1000 Hrs)
Flying (since 9/86): N43732 A65 Taylorcraft BC12D
earl_schroeder(at)juno.co Guest
Posted: Mon Jul 21, 2008 10:32 am Post subject: IR to ER alternator mod |
-- Steve Stearns <steve(at)tomasara.com> wrote:
<snip>
| Quote: | I don't have to agree with different viewpoints to appreciate them.
<snip>
| Quote: | if there was less defensive posturing, bile etc.
<snip>
I tend to agree with Steve! Especially the above quotes.
As long as the sender's name remains available, I can choose which to read..or agree with..
Earl
Posted: Mon Jul 21, 2008 11:43 am Post subject: IR to ER alternator mod |
At 11:14 AM 7/21/2008 -0600, you wrote:
Sorry. This is MY classroom and in this venue,
it's not a question of opinion and viewpoints.
It's a question of repeatable experiments and
good science.
<snip>
| Quote: | The 'I'm still right and you're still wrong and since you still don't
my reading, has been evident in both camps of the great debate seems to me
This List is not frequented by the "public
in general" and the vast majority of the public
in general would receive no benefit from hanging
out here. A "can't we all just get along"
idea has the effect of leveling the playing
field to average . . . mediocracy . . .
an environment crafted to upset the least
numbers of folks irrespective of their viewpoints
and opinions. I'd like to believe that the membership
of this List represents the top slice of individuals
struggling to build a better than average airplane.
When you select a doctor, engineer, lawyer or
teacher, do you want one who has been trained
in the "everybody is right to some degree" school
of thought . . . or is the demonstrable best in their
respective fields?
George and Paul have demonstrated nothing . . .
yet they've wasted a lot of $time$ as we attempted
to make nice. Eric has demonstrated a great deal
of initiative and creativity. See:
. . . and he is trying. And I've offered
to assist his endeavors right here on this List.
I'll leave it up to those who choose to
follow the conversation to judge the value
of investing the $time$.
Please do not mistake confidence and competence
with arrogance and conceit. I'm simply exercising
control over the decorum and quality of this
activity.
If your concerns are for making nice (no matter
what opinions might be offered) you'll need to
find another group that's more concerned with
making folks feel better than in helping them
do the best we know how to do at a budget they
can afford and technologies their skills and
$time$ can master.
andrewbutler(at)ireland.c Guest
Posted: Tue Jul 22, 2008 2:41 am Post subject: IR to ER alternator mod |
Debate is a good thing. Debates only become unpleasant when the participants steer from the rules of logic and induction to the more fuzzy exchanges that are bound by rules of social etiquette. Then people start talking about behaviour and style and all things socially complicated that have nothing whatsover to do with the topic at hand.
My understanding is that this forum was set up not for the purpose of making friends, but rather to help aviation enthusiasts located around the world produce better, safer and more cost effective aeroplanes. This all is much easier if we all stick to verifiable truths, based on logic and rational induction. If stating opinions is important to an individual, then that is fine, as long as those opinions can be demonstrated to be based on reason and logic that can be backed up by verifiable data. Those opinions are then more akin to truth, and are not of the individual at all.
Opinions that are of an individual (by virtue of not being demonstrated as being "truth"), is the source of debates that go sour because the owner of the opinion applies rules of social etiquette to the treatment of the opinion that just don't apply in the world of cold logic and induction. Logic and induction is like a dog with a bone and it won't let go until the truth is proven.
Sure if we all become friends thats great, but enemies? Can't see the logic in that!
Andrew Butler,
RV71700
Galway
Ireland
[quote]---
Posted: Tue Jul 22, 2008 5:28 am Post subject: IR to ER alternator mod |
Thanks for the clarification. I had not understood this list to be your
classroom but instead, had confused it for a user forum that supports
the free exchange of ideas (with which I have more experience). Your
list is an educational list and I'm appreciative of it. Can you (or
anyone else) suggest an additional aircraft electrical focused
list/forum that is moderated as a user forum that supports the free
exchange of ideas? I, in general, prefer to do my own sorting of wheat
from chaff and would like to add such a list to those (including this
one) in which I intend to continue to participate.
Respectfully,
Steve Stearns
Terry Watson
Joined: 09 Jan 2006 Posts: 290 Location: Seattle, WA USA
Posted: Tue Jul 22, 2008 8:20 am Post subject: IR to ER alternator mod |
I think some of you are missing an important point about the aeroelectric list: Matt set it up as Bob’s forum for answering builder’s questions about electrical aspects of small airplanes. Bob’s approach has been to make it a classroom, but the important point here is that it is Bob’s forum; he makes the rules. We don’t get to vote on how he runs his classroom or what kinds of disruptions or behavior he allows. That’s his call. I think he does it just right, but it really doesn’t matter what I think.
Terry
<snip>
<snip>
[quote] [b]
Posted: Thu Jul 24, 2008 6:53 am Post subject: IR to ER alternator mod |
At 09:17 AM 7/22/2008 -0700, you wrote:
| Quote: | I think some of you are missing an important point about the aeroelectric
list: Matt set it up as Bob s forum for answering builder s questions
about electrical aspects of small airplanes. Bob s approach has been to
make it a classroom, but the important point here is that it is Bob s
forum; he makes the rules. We don t get to vote on how he runs his
classroom or what kinds of disruptions or behavior he allows. That s his
call. I think he does it just right, but it really doesn t matter what I
think.
True. But lest anyone come to believe this is a
"closed" activity bounded by restraints on the
discussion of ideas, please consider the following:
It's my personal vision and mission goal that I
spend my time doing exactly what Steve is seeking -
presiding over an activity that considers every
idea and checks it for fit into what is already
known . . . i.e. does the new ingredient make
an old recipe better . . . or perhaps offers a
completely new recipe?
Steve stated that he had followed this List for
a time but I wonder if he was witness to the behaviors
of certain individuals who over a period of 5+
years brought no new ideas to the discussions.
Ideas they did produce were easily
Before being asked to leave, they indulged in
a lot of personal attacks ranging from simple
innuendo to outright lying.
I attempted to make-nice for years with some
notion of winning these folks over with reasoned
analysis and results of repeatable experiments.
But alas, it was not to be. It was only then
that I assumed the obvious duty of any good
teacher to control the decorum and quality
of the discussions . . . hence the response
he witnessed from me last week.
If it makes any difference, these same individuals
are infamous for their behaviors in other forums.
I've been given to understand that they've been
asked to leave other groups too. My patience
is probably greater than most but it IS limited.
We have more important things to do here than
spend time $time$ indulging irrational temper
tantrums. I do endeavor to be a good teacher.
Quashing ideas worthy of consideration is not
the behavior of a true teacher.
Posted: Thu Jul 24, 2008 7:01 am Post subject: IR to ER alternator mod |
At 10:37 AM 7/22/2008 +0000, you wrote:
| Quote: | Debate is a good thing. Debates only become unpleasant when the
logic in that!
Well stated sir. I was searching for those words
but you've already supplied them!
gmcjetpilot
Posted: Sat Jul 26, 2008 2:36 pm Post subject: IR to ER alternator mod |
| Quote: | From: "Robert L. Nuckolls, III"
<nuckolls.bob(at)cox.net (nuckolls.bob(at)cox.net)>
Subject: Re: Re: IR to ER alternator mod
| Quote: | >Bob, Eric, George, JetPilot and the rest of the list:
| Quote: | >following the list for a
| Quote: | >things electrical nor of lists supporting the free
>respectfully ask that Eric, George, JetPilot NOT
>go away.
| Quote: | Sorry. This is MY classroom and in this venue,
it's not a question of opinion and viewpoints. It's a
question of repeatable experiments and good
science.
For you to say you use SCIENCE is just funny.
It reminds me of the 80's Thomas Dolby song
"Blinded By Science" where in the chorus he
yells, "SCIENCE"!
What do I use, egg salad? You are talking to people,
including me, with engineering and science degrees.
Any freshman engineering, science or medical
student learns scientific methods in their labs.
That is great you use science, but Bob what
relevant facts do you bring with your "science".
What repeatable test have you done regarding IR
to ER conversions?
Blurting out "repeatable test" and "good science" is
a red herring, a non sequitur. It seem like you say it
to impress.
I have 1000's of flight hours behind IR alternators.
That is service history. I run my "test" ever time I fly.
Every time I do maintenance and check the brushes,
I am doing a test and so are all my friends with IR
alternators.
I do have more advanced education in engineering,
math and science than you Bob, as well as more flight
experience and ratings. Advance math is the language
of science and the absolute in problem solving and logic.
Therefore I must be right since I have more education?
Education is irrelevant ...... just like the repeatable
test pronouncements are irrelevant. You can't win
arguments but just saying "repeatable test". You
can try but it doesn't really work.
BTW before "repeatable test" you must determine
if a test is VALID! You have to know what and
why you are testing, what to measure and how to
measure it. Than you have to validate the data,
correlate with theoretical analysis or other known
data. That is why flight test is done, to verify the
analysis and component test. I do flight test.
I flight test my IR alternators many times a week, as
do 100's of other pilots with out problem. My IR
alternator has been shown to be reliable, as many
friends with IR alternators in their planes have shown.
Matt wants a civil tone and contribution from
many. I think that is what most members of the list
want as well. They just don't want the fighting. We
can spar but I rather not.
BOB I HAVE INVITED YOU TO JOIN ME IN
TESTING AND IMPROVING IR ALTERNATORS. WHY DON'T YOU?
| Quote: | >since you still don't agree with me let me
>the great debate seems to me to be not just
>the list-reading public in general.
| Quote: | This List is not frequented by the "public in
general" and the vast majority of the public in
out here. A "can't we all just get along" idea has the
| Quote: | effect of leveling the playing . . . field to average .
. . mediocracy . . .an environment crafted to upset
the least numbers of folks irrespective of their
viewpoints and opinions. I'd like to believe that
the membership of this List represents the top
slice of individuals struggling to build a better
Bob you may think I am the "bottom slice" but you
don't know me. I have been involved in building
planes both airliners as and engineer out of college
and kit planes since 1985. One of my planes, RV-4,
won a workmanship award at a major EAA fly-in.
There's nothing mediocre or average about what I do,
and have much in common with builders as a builder.
I did go to college and grad school and paid for
every nickel of it my self, by working. No excuses
I am proud of that and should be. I also paid every
nickel of my initial flight training through 5
instructor ratings and ATP, which helped me get
my flying career going, three type ratings and
+11,000 hours later and still counting. There's nothing
mediocre Bob, I just bring different things ideals to the
table as you do.
| Quote: | teacher, do you want one who has been trained
respective fields?
| Quote: | yet they've wasted a lot of $time$ as we
attempted to make nice. Eric has demonstrated a
great deal of initiative and creativity. See:
Well that is just rude and untrue. I have helped
many people Bob and I know they appreciate it. I
know Paul has interesting things to say, which I
enjoy, which helped me. The only one upset is YOU!
And how do I cost you money? You mean by
recommending cool gear that is not B&C, which
you get a kick back from? Does that make you
mad? Is that what it is about? OK I will not
recommend Plane Power any more. It is a
free country and free market. I have no interest
in Plane Power , Transpo or Perihelion Design.
I do want a rich base of knowledge and ideas
from more than ONE person. I also want more
than one vendor for parts and competition to
keep prices down. That is the American way.
THE BIG UNKNOWN?
You claim there is no detailed info on IR to satisfy
you, so you disqualify its use. You just don't want
to accept the info. I really don't think more info
would make a difference no matter what I show
you. I don't think you understand whats going on
in an IR.
You are set on one idea. Which I am fine with
but you seemed like you can tolerate anyone
ignoring your advice. If they do they are either
dumb or trolls. That is harsh and dogmatic.
| Quote: | . . . and he is trying. And I've offered to assist
his endeavors right here on this List. I'll leave it
up to those who choose to follow the
conversation to judge the value of investing the
$time$.
| Quote: | Please do not mistake confidence and
competence with arrogance and conceit. I'm
simply exercising control over the decorum and
quality of this activity
I agree people can make their own minds up. Why
are you afraid of other ideas? You claim other input
is inferior? Why? More ideas the better.
If your concepts are better they will shine. You
have to trust people to have the brains to make
their own minds up. I just want to help people
that DO want to IR alternators. I don't want to
sell them on it, only improve upon it for those
committed to IR. No criticism of your concepts.
| Quote: | If your concerns are for making nice (no matter
making folks feel better than in helping them do
the best we know how to do at a budget they can
afford and technologies their skills and $time$
can master.
> Bob . . .
Bob actually I think you are a little insecure. Bob
every one agrees and recognizes you are THE
expert, the MAIN contributor, but you are proving
it all the time. Stop proving it, we all know and
respect that. But respect is a two way street.
Your last two post have helped me understand how
you think and see yourself in this forum, WOW~!
I get it. I'll try to say out of your way.
Kellym
Posted: Sat Jul 26, 2008 7:09 pm Post subject: IR to ER alternator mod |
How incredibly arrogant and rude, George. I don't care about your
ratings or your degrees. If you were so smart, you wouldn't be flying
for hire.
On listservs I run, you would be gone, right now, blocked from ever
rejoining for your series of insulting posts and arguments you have been
told are not welcome. Your lengthy post added zero, was nothing but self
flagellation and insults.
I ask that Matt block you from this list if Bob won't do it.
This isn't a general list for debate, it is Bob's list to discuss his
book and its recommendations. You obviously are too lazy to start your
own list and rather interfere with list belonging to someone else.
That is most offensive. The rest of us subscribe to discuss topics
AeroElectric. We don't want to talk about you. I'll filter your posts
out from no on, as I have no respect for your antagonistic approach.
gmcjetpilot(at)yahoo.com wrote:
KCHD |
