pgroell(at)yahoo.fr Guest
Posted: Sat Jul 26, 2008 12:17 am Post subject: Stick wiring cable |
Hello all,
While rummaging through my household cables, I found some Ethernet cable I used to install a network at my home.
This looks like an 8 wires, color coded, 24 AWG cable (it’s also shielded). Would there be any drawbacks using this cable to wire my stickgrip from grip to a connector (probably D-SUB) at the base of the stick?
Thanks for your input.
Pascal GROELL
RV-7A (near Paris, France)
www.notreavion.net
nuckolls.bob(at)cox.net Guest
Posted: Sat Jul 26, 2008 3:37 am Post subject: Stick wiring cable |
At 10:12 AM 7/26/2008 +0200, you wrote:
| Quote: | Hello all,
This looks like an 8 wires, color coded, 24 AWG cable (it s also
Most Ethernet cable is solid strands of wire.
It's not a wire designed for flexibility or
robustness under vibration. You could give it
a try. It might last quite some time before
needing a replacement.
( -Thomas Paine 1776- )
Posted: Sat Jul 26, 2008 4:56 am Post subject: Stick wiring cable |
<nuckolls.bob(at)cox.net>
> Hello all,
> the stick?
Consider cutting up one of the off-the-shelf ethernet patch cables. They
should be stranded.
The most flexible & durable stuff I've ever seen that's easy to find is
regular old telephone patch cord, but terminating it with anything other
than the standard displacement-type RG connectors can be a problem.
Charlie
Posted: Sat Jul 26, 2008 7:59 am Post subject: Stick wiring cable |
| Quote: | >>While rummaging through my household cables, I found some Ethernet cable
> Bob . . .
should be stranded.
I did not know that. Thanks! I've got some laying
around here somewhere that I'll investigate that
condition. Good to know.
Posted: Sat Jul 26, 2008 8:38 am Post subject: Stick wiring cable |
>>> the stick?
>> Bob . . .
> They should be stranded.
Uhh... I hedged a bit with the 'should' in the previous post. Here's a
link to the Belden products. Some are solid, some are stranded. The
better patch cables are flexible enough that it's hard to believe that
they have 8 solid conductors, but it's worth checking.
http://www.belden.com/07Markets/07_Industrial/07_Industrial_Products/Industrial_Ethernet_Cable.cfm#ethernet
Charlie
Posted: Sat Jul 26, 2008 8:48 am Post subject: Stick wiring cable |
Hello,
My cable is indeed stranded, I'll count the strands next time I'm in the
workshop.
Best regards
Pascal
| Quote: | -----Message d'origine-----
De : owner-aeroelectric-list-server(at)matronics.com [mailto:owner-
aeroelectric-list-server(at)matronics.com] De la part de Robert L.
Nuckolls, III
Envoyé : samedi 26 juillet 2008 17:53
À : aeroelectric-list(at)matronics.com
Objet : Re: Stick wiring cable
cable
the stick?
>> Bob . . .
They
>should be stranded.
deej(at)deej.net Guest
Posted: Sat Jul 26, 2008 9:44 am Post subject: Stick wiring cable |
| Quote: | Most Ethernet cable is solid strands of wire.
Often ethernet cable intended for building wiring is solid, but that
destined for patch cables is stranded. If it is a roll of cable, the
side of the box/spindle should say on it which type it is, otherwise
just cut a piece of the wire apart and look at it. In my experience you
have about a 50/50 chance of it being either.
-Dj
Dj Merrill
Sportsman 2+2 Builder #7118
http://deej.net/sportsman/
"Many things that are unexplainable happen during the construction of an
airplane." --Dave Prizio, 30 Aug 2005
