nuckollsr(at)cox.net Guest
Posted: Thu Mar 09, 2006 6:40 pm Post subject: Annunciated Parameters wish list . . . . |
Just for grins, I'll toss the question out to the list.
From of the list items below, what additional or alternative
points of interest might be important enough to light a light
and/or blow in your ear?
The wish list now stands at:
Main Volts Lo
Aux Volts Lo
Left Fuel Lo
Right Fuel Lo
Oil Pres Lo
Canopy Latch
OAT Warn
Pitot Heat
Coolant Temp
Coolant Pres
Coolant Low
Oil Temp
Turbo (control malfunction) (yellow)
Boost pump ON (white)
Fire
Flaps Warn
Fuel Pump ON
Starter engaged
P-Mag Maint
Prop Overspeed
Gear extension Warning
Nose Gear
Lt Mn Gear
Rt Mn Gear
< What is so wonderful about scientific truth...is that >
< the authority which determines whether there can be >
< debate or not does not reside in some fraternity of >
< scientists; nor is it divine. The authority rests >
< with experiment. >
< --Lawrence M. Krauss >
hdwysong(at)gmail.com Guest
Posted: Thu Mar 09, 2006 9:09 pm Post subject: Annunciated Parameters wish list . . . . |
A few more from the turbine community, Bob (... if applicable):
Chip Detect
BVC Fault
Anti-Ice
Fuel Filter
Oil Filter
Fuel Pressure
Gen
All are fault lights on a Caution/Advisory panel that I've stared at
for one too many hours...
D
On 3/9/06, Robert L. Nuckolls, III <nuckollsr(at)cox.net> wrote:
gcomfo(at)tc3net.com Guest
Posted: Fri Mar 10, 2006 4:02 pm Post subject: Annunciated Parameters wish list . . . . |
