hotwheels
rv10rob(at)gmail.com Guest
Posted: Thu Jul 24, 2008 8:30 am Post subject: Sb 08-6-1: What's the equivalent of an AN470 rivet? |
I had a couple of these when doing the SB (I did it without removing the aft deck--more trouble than it was worth in retrospect). I used CherryMax CR-3243-4-x rivets. Just drill to #27 and they install like normal blind rivets.
This place sells them individually: http://www.ddaircraft.com/subcategory.cfm?Subcategory=CR3243&Category=RIVETS
-Rob
On Thu, Jul 24, 2008 at 9:00 AM, Jay Brinkmeyer <jaybrinkmeyer(at)yahoo.com (jaybrinkmeyer(at)yahoo.com)> wrote:
[quote]--> RV10-List message posted by: Jay Brinkmeyer <jaybrinkmeyer(at)yahoo.com (jaybrinkmeyer(at)yahoo.com)>
What an acceptable substitute for an AN470 rivet when a drilled out hole gets too large to fit the old rivet? My best guess are #1 or #2. The others might be fun to try on someone else's project.
Cheers,
Jay
1) AN3 + washer/nut
2) #8 pan head screw + washer/nut
3) duct tape
4) chewing gum
5) proseal
6) bailing wire
7) more primer
a good place for an adel clamp
Cheers,
Jay
flywrights(at)yahoo.com Guest
Posted: Thu Jul 24, 2008 10:35 am Post subject: Sb 08-6-1: What's the equivalent of an AN470 rivet? |
I used 3 AN3-X bolts in my whole SB; two . There for a while I was wondering if I was helping or hurting the structure.
Rob
pascal(at)rv10builder.net Guest
Posted: Thu Jul 24, 2008 10:57 am Post subject: Sb 08-6-1: What's the equivalent of an AN470 rivet? |
I would not recommend using the old rivet, regardless of how much chewing
gum you use!
Do you mean the hole is too large for the head of a 470? if so 1 or 2 seem
fine if you mean the hole is smaller than the head but to big to fit the
same length in than simply go up one length of the rivet aka AD4704-4 to
AD4704-5, etc..
From: "Jay Brinkmeyer" <jaybrinkmeyer(at)yahoo.com>
Sent: Thursday, July 24, 2008 9:00 AM
To: "RV10" <rv10-list(at)matronics.com>
Subject: Sb 08-6-1: What's the equivalent of an AN470 rivet?
Cheers,
Jay
1) AN3 + washer/nut
3) duct tape
4) chewing gum
5) proseal
6) bailing wire
7) more primer
Cheers,
Jay
toaster73(at)embarqmail.c Guest
Posted: Thu Jul 24, 2008 12:50 pm Post subject: Sb 08-6-1: What's the equivalent of an AN470 rivet? |
I think the cherry max rivets are oversized to deal with slightly larger
holes due to removed rivets.
-CHris
#40072
AV8ORJWC
Posted: Thu Jul 24, 2008 7:38 pm Post subject: Sb 08-6-1: What's the equivalent of an AN470 rivet? |
Pascal, when an AN470 universal or an AN426 countersink rivet hole is enlarged or elongated, the next step is to drill for a OOPs rivet which has an NAS designation. They are designed to hide the travesty. I have trays of them at Paul Grimstad's (no reflection on his drilling prowess). I cannot recall the ID number but Paul could fill you in. My trays are -3, -4 and -5's.
The technique of drilling, removing and re-installing comes to all who acquire the Repairman Certificate. Those who use Professional Gunslingers won' know what they are missing.
John (over night in Miles City, Montana enroute to the BIG ONE or Aviation Mecca '08.)
From: owner-rv10-list-server(at)matronics.com on behalf of pascal
Sent: Thu 7/24/2008 11:54 AM
Subject: Re: Sb 08-6-1: What's the equivalent of an AN470 rivet?
--> RV10-List message posted by: "pascal" <pascal(at)rv10builder.net>
gum you use!
AD4704-5, etc..
| Quote: | --> RV10-List message posted by: Jay Brinkmeyer <jaybrinkmeyer(at)yahoo.com>
Cheers,
Jay
1) AN3 + washer/nut
3) duct tape
4) chewing gum
5) proseal
6) bailing wire
7) more primer
Cheers,
Jay
&ghref="http://www.matronics.com/Navigator?RV10-List">http://www.matronic &href="http://forums.matronics.com/">http://forums.matronics.com
nbsp; - List Contribution Web Site bsp; -Matt Dralle, List href="http://www.matronics.com/contribution">http://www.matronics.com/c=================
Posted: Thu Jul 24, 2008 8:44 pm Post subject: Sb 08-6-1: What's the equivalent of an AN470 rivet? |
certainly good points and thanks to Tim's recommendation I have a draw of Oops rivets myself. In the SB case however these are 470-4 rivets not 470-3 than require an Oops to repair. Jay is looking for an option for his larger 470-4 rivet, I have used one size larger with -4 rivets. Done slowly has shown good results.
Also as a reminder from the Section 5, Jay was right with his two options- "One of the common calls we get is “I had to drill out a bad rivet and now the hole is oversize. What do I do?”. Sometimes this is done multiple times in the same hole and now the hole is so large that the builder has to use a bolt and nut instead of a rivet."
Additionally for us gunslingers, with the technique of drilling maybe shouldn’t be drilling to start with:
EXCERPT from Alcoa Aluminum Rivet Book, dated 1984.
“The standards to which driven rivets should conform are frequently uncertain. In addition to dimensions and perfection of shape,
inspection is concerned with whether the drive head is coaxial with the shank (not “clinched”) and whether there is excessive
cracking of the heads. It has been determined that even badly cracked heads are satisfactory from the standpoint of static strength,
fatigue strength and resistance to corrosion. (Poorly set and cracked) rivet heads were tested in tension to determine how well
formed a head has to be in order to develop full strength. The tensile strengths of all the rivets were within five per cent of the
strongest. The test indicated that minor deviations from the theoretically desired shape of head are not cause for concern or replacement.
The second rivet that is driven in any one hole likely to be more defective than the first because the hole is enlarged
and rivet will be more likely to buckle and form an imperfect head."
I stand by my using a larger rivet in this case because we HAD to drill and rivet again. I did it and it worked just fine.
Pascal
Sent: Thursday, July 24, 2008 8:29 PM
Subject: RE: Sb 08-6-1: What's the equivalent of an AN470 rivet?
gum you use!
AD4704-5, etc..
Cheers,
Jay
1) AN3 + washer/nut
3) duct tape
4) chewing gum
5) proseal
6) bailing wire
7) more primer
Cheers,
Jay
AV8ORJWC
Posted: Fri Jul 25, 2008 4:48 am Post subject: Sb 08-6-1: What's the equivalent of an AN470 rivet? |
Laying here in the NoTell Motel in Miles City the revelation came to me last night. NAS1097-x-x
From: owner-rv10-list-server(at)matronics.com on behalf of John Cox
Sent: Thu 7/24/2008 8:29 PM
gum you use!
AD4704-5, etc..
Cheers,
Jay
1) AN3 + washer/nut
3) duct tape
4) chewing gum
5) proseal
6) bailing wire
7) more primer
Cheers,
Jay
AV8ORJWC
Posted: Fri Jul 25, 2008 4:52 am Post subject: Sb 08-6-1: What's the equivalent of an AN470 rivet? |
Drilling rivets do not necessarily mandate going oversized after removal. The need for a large bit is often the result of eyesight, hand coordination and the possibility of multiple sheets of skin fastened together. It is not uncommon using typical techniques to get up to three removals before things begin to get questionable. Us older guys use more OOPs and the younger tykes can often pull off miracles.
The OOPs can keep the head appearing to conform to a correctly driven original rivet.
I keep lots of OOPs and seldom need them.
Sent: Thu 7/24/2008 9:42 PM
Pascal
gum you use!
AD4704-5, etc..
Cheers,
Jay
1) AN3 + washer/nut
3) duct tape
4) chewing gum
5) proseal
6) bailing wire
7) more primer
Cheers,
Jay
johngoodman
Posted: Fri Jul 25, 2008 5:31 am Post subject: Re: Sb 08-6-1: What's the equivalent of an AN470 rivet? |
Jay,
I think the thread has drifted a little. The NAS1097 is an Oops rivet for an AN426, and you were talking about a buggered hole for an AN470A4, right? My choices would be:
AN470A5-x with a tensile strength of 16,000
AN470AD5-x with a tensile strength of 38,000
#8 screw with a tensile strength of 60,000
AN3-x with a tensile strength of 125,000
John
_________________ #40572 Phase One complete in 2011 |
hotwheels
Posted: Sat Jul 26, 2008 7:02 pm Post subject: Re: Sb 08-6-1: What's the equivalent of an AN470 rivet? |
This is good information and seems to reflect exactly what I was wanting to know... How good is good enough? The original hole was way buggered (just one!).
The new hole is fairly large and at this point it's probably easiest to just live with a screw/nut and call it a day as riveting this particular hole again could just make it worse (Murphy is alive and well).
Cheers,
Jay
<snip>
would be:
John
#40572 QB Fuselage, wings finished
N711JG reserved
AirMike
Posted: Sun Jul 27, 2008 11:24 pm Post subject: Sb 08-6-1: What's the equivalent of an AN470 rivet? |
John Goodman has it correct. Bolt or 470-AD5-x rivets. Spruce sells some of the #5 rivets - I bought a few (470-AD-5-6 ) and the #5 set to fix the buggered holes in my SB work. About 10-12 bucks - not too bad to set. I used the same 60# of air pressure that I used on the #4 rivets and whacked a few extra times. I think that we hit it 12-15 times. We sill screwed up one mfg head, but decided not to drill it out as it is soooo much stronger than the #4. Cheap piece of mind.
_________________ See you OSH '18
Q/B - sold. |
John Kirkland
Joined: 13 Jan 2006 Posts: 19 Location: South Weber, UT
Posted: Mon Jul 28, 2008 11:39 am Post subject: Re: Sb 08-6-1: What's the equivalent of an AN470 rivet? |
I was able to scrounge a small handfull of AN470AD5 from my local A&P at the airport just for the asking. I just cut to the length I need.
_________________ RV-10 #40333
N540XP (reserved) |
