		occom
				 Posted: Sat Feb 17, 2007 11:13 am    Post subject: varnish before or after? |
				I cannot find this advice in my old assembly manual  and figured I'd ask the list. Do you varnish new ribs before or after gluing  them in?? It might be better to reply to occom(at)ns.sympatico.ca (occom(at)ns.sympatico.ca) rather than start  an argument if it can go both ways.
  |  | - The Matronics Kitfox-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		lcfitt(at)sbcglobal.net Guest
				 Posted: Sat Feb 17, 2007 12:50 pm    Post subject: varnish before or after? |
				Hi Dave,
 I found the procedure in my builders manual.  Varnish after all assembly on
 the wing is complete.  It is part of the wing pre-cover porcedures.
 Lowell
		kitfox555(at)sbcglobal.ne Guest
				 Posted: Sun Feb 18, 2007 6:29 pm    Post subject: varnish before or after? |
		jlfernan
				 Posted: Mon Aug 04, 2008 2:53 pm    Post subject: Re: varnish before or after? |
				Now, what about on the HS and elevators?  Some of the ribs butt up against cross members, and if you glue them first, than you can't do the area next to the cross member? Should I varnish them and then scuff them before gluing? Also I must have new style ribs.  Instead of cutting a slit so you can twist the rib over the diagonal members, these are slit all the way to the end.  Should I close this slit also?
  _________________ Jorge Fernandez
Supersport
Fuselage/Forward Controls
http://websites.expercraft.com/jlfernan/ |
		rjdaugh
				 Posted: Mon Aug 04, 2008 5:52 pm    Post subject: varnish before or after? |
				Jorge,
 I glued first and then varnished them in place.  I think that that is the
 best way.
 Randy
 Series 5/7
 912S  200 hours.
  _________________ Randy
Kitfox 5/7 912S
Black Hills, South Dakota |
