patrick.pulis(at)seagas.c Guest
Posted: Mon Jul 28, 2008 6:10 pm Post subject: Leak Proofing the Fuel Sender |
pascal(at)rv10builder.net Guest
Posted: Tue Jul 29, 2008 6:12 am Post subject: Leak Proofing the Fuel Sender |
Patrick;
I followed Tim's insight and used proseal around the gasket. I have heard of many other options as many mentioned the difficulty of removing it later, if needed.
http://www.myrv10.com/N104CD/wing/20041107/RV200411060023.html
I figure if Proseal is used for the whole tank it should work fine for the gasket.
Pascal
[quote] From: Patrick Pulis
Sent: Tuesday, 29 July 2008 11:37 AM
To: 'rv10-list(at)matronics.com' ([email]\'rv10-list(at)matronics.com\'[/email])
Subject: RE: Leak Proofing the Fuel Sender
According to the installation instruction supplied with the stock standard fuel tank sender supplied by Vans, it is recommended that the supplied neoprene gasket be installed between the tank wall and the sender unit (and replaced if the sender is ever removed for inspection/replacement).
Other than the recommendation to use the gasket, there are no specific instructions as to the use (or otherwise) of any fuel proofing compound (e.g. - Proseal) to leak proof the installation of the float sender unit.
I have elected to use sealed nut plates (in lieu of the Vans standard) to attach the fuel tank sender to the tank, so I only need to seal the contact area between the sender unit face and the tank rib.
From the various photos that I have seen, other builders have used Proseal to leak proof the sender to the tank, and thus this appears to be the way to go.
Could anyone please confirm my assumptions regarding the application of proseal to achieve a fuel/leak proof seal at this location, coupled with confirming (or otherwise) the use of the supplied gasket.
Your thoughts would be very much appreciated please.
Patrick, RV-10 #40299, South Australia
======================nbsp; Navigator Photoshare, and href="http://www.matronics.com/Navigator?RV10-List">http://www.matronic via the Web href="http://forums.matronics.com">http://forums.matronics.com
_-========================nbsp; generous bsp; href="http://www.matronics.com/contribution">http://www.matronics.com/c=================
Posted: Tue Jul 29, 2008 4:06 pm Post subject: Leak Proofing the Fuel Sender |
dmasys(at)cox.net Guest
Posted: Wed Jul 30, 2008 4:06 pm Post subject: Leak Proofing the Fuel Sender |
Patrick,
By chance, I happen to have done the Van's service bulletin on my RV-7A last weekend that applies a safety wire to the fuel pickup in each tank. To do this one has to remove the fuel tank access plates, which are essentially identical to the ones on the inboard tank rib of the RV-10. I had done a little 'randomized' experiment by using Van's cork gasket on one side, sealed with ProSeal, and on the other side I just used ProSeal without any cork gasket, as was recommended by Gary Sobek, my Tech Counselor at the time. The -7A is a bit over three years old, and here is what I can report: both the ProSeal-only and the ProSeal-applied to cork gasket work fine to hold the fuel in the tank with no leaks. Removing the side with the cork gasket was much easier, since the cork is soft and a putty knife can be slipped in between the pieces and the cover plate pried away and popped loose without much difficulty. The ProSeal only side was quite a bit more difficult to break loose, and required sliding a single edge razor blade between the bonded surfaces most of the way around the circumference of the cover plate. However, when it came loose it was somewhat easier to clean up using a razor blade as a scraper combined with MEK.
So the decision to use a gasket or not really comes down to ease of future maintenance. Either way keeps the fuel in the tank.
Hope this helps,
-Dan Masys
RV-10 N104LD back from OSH
RV-7A N747DL
Posted: Wed Jul 30, 2008 9:29 pm Post subject: Leak Proofing the Fuel Sender |
Thanks Dan
AV8ORJWC
Posted: Sun Aug 03, 2008 4:33 pm Post subject: Leak Proofing the Fuel Sender |
Not to attract contrarian comments but the use of metallic scrapers on aluminum might be best avoided. We regularly complete such tasks with the use of MEK and plastic scrapers (and barrier gloves). Razor blades and putty knifes are a quick way to be pointed to the door on air carrier aircraft. Your family members deserve no less.
FWIW
John C.
John Ackerman
Joined: 19 Jun 2006 Posts: 130 Location: Prescott, AZ
Posted: Sun Aug 03, 2008 9:03 pm Post subject: Leak Proofing the Fuel Sender |
John, what is the reason given for no metallic scrapers? Crack
initiation? Accidental cuts and gouges?
What do you do if you need something very thin as Dan did (see below)?
John Ackerman 40458
On Aug 3, 2008, at 5:25 PM, John Cox wrote:
> to break loose, !
> Hope this helps,
> -Dan Masys
> RV-7A N747DL
Kelly McMullen
Posted: Mon Aug 04, 2008 6:15 am Post subject: Leak Proofing the Fuel Sender |
Same reason you don't use steel wool on aluminum. It can initiate
corrosion. Yes, steel scrapers will scratch the aluminum and can
generate all the issues of deep scratches. Phenolic scrapers, or
scrap plexiglass ground into a scraper works pretty well.
I don't disagree with Dan using what he did for that purpose(getting
to skins apart), IF you recognize that close inspection will be
required and you may have to scrap a piece if it gets too scratched.
On way of reducing risk is to select stainless steel putty knife, to
minimize the corrosion aspect.
Of course John is giving you the airline point of view, where tanks
frequently need attention, and costs are much higher, as are risks,
along with the maximum level of regulation/oversight. Different
standards, different needs...but the physics of steel and aluminum
remain the same.
On Sun, Aug 3, 2008 at 9:58 PM, John Ackerman <johnag5b(at)cableone.net> wrote:
John, what is the reason given for no metallic scrapers? Crack initiation?
John Ackerman 40458
>> side was quite a bit more difficult to break loose, !
>> Hope this helps,
>> -Dan Masys
>> RV-7A N747DL
A&P/IA, EAA Tech Counselor
KCHD |
AV8ORJWC
Posted: Mon Aug 04, 2008 7:51 am Post subject: Leak Proofing the Fuel Sender |
Let me add that we sneak Skin Knives into some applications (also a terminable offence). Blending of scratches requires a 10:1 or 15:1 taper (depending on the SRM = Structural Repair Manual). You all have written one to effect repairs, haven't you? it is amazing how deep a scratch goes when force is used. Remember that the Alclad pure coating is not very thick. Five percent on each side for a total of 10 percent coating. So 0.032" means 0.0016" on each surface. On the RV-12 using 0.020 skin it is even more critical. Just hand force used on a tool can permanently stretch the skin - forever.
"Skin knives" and "thread taps" are two ways to get quickly busted. We use them, on the sly and with high degree of situational awareness and desire for job security.
John - back to GRAVES tonight after two weeks with real aviators.
John Ackerman
Posted: Tue Aug 05, 2008 9:30 am Post subject: Leak Proofing the Fuel Sender |
Kelly, I wondered about that - certainly if particles of iron came off
the scraper, it would be possible to form a corrosion cell, but a fair
amount of material would be required to establish a significant
corrosion rate. For heaven's sake don't ask me to quantify that!
Steel wool is different - relatively large slivers do break off and
lodge in the surface
More wondering ...
Is there a concern wherever steel meets aluminum? (answer, I think:
"Of course, but Al forms a protective Al2O3 coating, limiting
corrosion rate to an acceptable level except under really adverse
circumstances")
Comment?
John
On Aug 4, 2008, at 7:12 AM, Kelly McMullen wrote:
remain the same.
> initiation?
> below)?
> John Ackerman 40458
>> scrapers on
>> with the
>> and putty
>> aircraft.
>>> the cork
>>> and the cover
>>> ProSeal only
>>> plate.
>>> using a
>>> Hope this helps,
>>> -Dan Masys
>>> RV-7A N747DL
John Ackerman
Posted: Tue Aug 05, 2008 9:35 am Post subject: Leak Proofing the Fuel Sender |
Scratches, John:
Everything in this non-ideal world gets scratched. I believe the issue
is what are the stresses on the part, how big is the scratch, and how
sharp are its corners. I certainly don't disagree with what you say,
and your post is very helpful. Do you have any more quantitative
guidance for us? It would be most welcome.
John Ackerman 40458
forever.
