Engine 'first' start
recapen(at)earthlink.net
PostPosted: Wed Aug 06, 2008 5:14 am    Post subject: Engine 'first' start Reply with quote
Folks,
My list of things to do before engine start is getting small and I think it is time to consider letting the dragon breathe some fire.....
I have an Aerosport Power IO360B1F6 (AFP injection, LASAR mags) with a MT three blade prop.
I have the Lycoming manual page for their cold engine start procedures and I have incorporated that in to my engine cold start checklist:
Alt air - off
Prop - high RPM
Fuel valve - select tank
Purge valve - run
Master - on
Fuel boost pump - on
Throttle - full open
Mixture - rich until fuel flow is noted on guage
Throttle - Idle
Mixture - lean
Fuel boost pump - off
Throttle to 1/4
Clear prop
Ignition switch - START
Mixture - to rich smoothly while cranking
Ignition switch - both when engine fires
Have any of you found that you need to deviate from these instructions in order to get consistent starts?
Thanks for any input,
Ralph
brucebell74(at)sbcglobal.
PostPosted: Wed Aug 06, 2008 5:44 am    Post subject: Engine 'first' start Reply with quote
Follow the AFP start procedure!
Bruce Bell, RV4 N23BB
PostPosted: Wed Aug 06, 2008 6:01 am    Post subject: Engine 'first' start Reply with quote
I'll go back and review the AFP procedure to see howw it meshes - I don't have it handy.....
