rivet squeezer
carlossa52(at)gmail.com
PostPosted: Wed Aug 06, 2008 5:37 pm    Post subject: rivet squeezer Reply with quote
Hello, all
I intend to buy a (manual) rivet squeezer (so far I have borrowed one), and I would appreciate to read about your experiences with these tools:
http://www.aircraftspruce.com/catalog/topages/handrivetsqueezer.php
http://www.ustool.com/usstore.asp?WCI=wciViewItem&WCE=90997s
http://www.ustool.com/usstore.asp?WCI=wciViewItem&WCE=90995s
http://tinyurl.com/58baoc (aviation tools, eBay store)
(Brown Tools seems to be offline, and Avery's squeezer is too expensive http://www.averytools.com/p-497-avery-hand-rivet-squeezers.aspx )
Thanks for your comments
do not archive (yet)
Carlos
CH601-HD
Montreal, Canada
jaybannist(at)cs.com
PostPosted: Wed Aug 06, 2008 6:16 pm    Post subject: rivet squeezer Reply with quote
Carlos,
I bought one of the US Industrial Tool squeezers with the removable "C" yoke. It has served my needs well.
Jay in Dallas
pdn8r(at)yahoo.com
PostPosted: Thu Aug 07, 2008 2:48 am    Post subject: rivet squeezer Reply with quote
An important consideration is the throat depth. Remember if you buy a 2" squeezer then you can only reach rivets no more than 2" from the edge. The squeezers with the interchangeable heads ie: 1", 1.5", 2" etc. give you more flexibility, although more expensive in most cases it is actually cheaper if you end up having to buy more than 1 squeezer just for additional throat depths.
Bill PaganEAA Tech Counselor #4395
--- On Wed, 8/6/08, Carlos Sa <carlossa52(at)gmail.com> wrote:
[quote]From: Carlos Sa <carlossa52(at)gmail.com>
Subject: rivet squeezer
To: zenith-list(at)matronics.com, zenith701801-list(at)matronics.com
Date: Wednesday, August 6, 2008, 9:37 PM
Hello, all
Carlos
CH601-HD
Montreal, Canada
Jeyoung65(at)aol.com
PostPosted: Thu Aug 07, 2008 7:03 am    Post subject: rivet squeezer Reply with quote
Hi Carlos, Not sure why you would buy a rivet squeezer when the spars are the only items using solid rivets. Harbor Fright anvil and a two pound hammer worked great for me. Jerry of Ga
In a message dated 8/6/2008 9:38:42 P.M. Eastern Daylight Time, carlossa52(at)gmail.com writes:
Hello, all
Carlos
CH601-HD
Montreal, Canada
f="http://www.matronics.com/Navigator?Zenith-List">http://www.matronics.com/Navigator?Zenith-List
.matronics.com/">http://forums.matronics.com
://www.matronics.com/contribution">http://www.matronics.com/contribution
Looking for a car that's sporty, fun and fits in your budget? Read reviews on AOL Autos.
notsew_evets(at)frontiern
PostPosted: Thu Aug 07, 2008 7:19 am    Post subject: rivet squeezer Reply with quote
You will need a squeezer sometime in your aviation life.
Maybe not on the "basic" Zenith but you will add this and that in the future and a hammer is not the professional way to squeeze.......
Years ago I bought the $119 model and its paid for itself many times over. I do wish I would have paid just a little more and purchased one with a deeper throat..
Steve
Arizona
N 9554 W
PostPosted: Thu Aug 07, 2008 7:25 am    Post subject: rivet squeezer Reply with quote
There are few spots where you need solid rivets, according to the plans.
But I have a couple of other applications where I definitely like the looks of solid rivets (yes, I know, more time and effort - but what do I care, it's been some 8 or 9 years already, a couple more is only 10%...).
Examples are access panels (1) to the instrument panel, from the top of the fuselage and (2) to the wing tip, to install / repair lights.
See attached photo.
Cheers
Carlos
CH601-HD (remember the HD?!), plans
2008/8/7 <Jeyoung65(at)aol.com (Jeyoung65(at)aol.com)>
In a message dated 8/6/2008 9:38:42 P.M. Eastern Daylight Time, carlossa52(at)gmail.com (carlossa52(at)gmail.com) writes:
 Filesize:  64.37 KB
 Viewed:  337 Time(s)
psm(at)att.net
PostPosted: Thu Aug 07, 2008 8:20 am    Post subject: rivet squeezer Reply with quote
Hi Carlos,
I agree with you. Solid rivets are nice for installing nut plates in
most applications. I use the soft aluminum rivets for this ("A"
rather than "AD"). They are very easy to set with a 1 ton arbor
press or just a small hammer and steel bar for bucking.
Paul
XL nearly done.
is only 10%...).
PostPosted: Thu Aug 07, 2008 5:03 pm    Post subject: rivet squeezer Reply with quote
Thanks to all that offered their comments, on and off list.
Happy building, folks !
Carlos
CH601-HD, plans
tail feathers, right wing done, making left wing tip
