daberti(at)sbcglobal.net Guest
Posted: Wed Aug 06, 2008 6:04 pm Post subject: Rotax Engines-List: 91 octane and time to be heard |
I'm confused, are you agreeing with Chevron or want Auto fuel made available
to all of the aviation community? Do you agree with the implication that
any 91 octane unleaded fuel (automotive based) Chevron supplies to an
airfield is contaminated, cross blended, or have an ethanol content and
octane rating that they cannot document? Are you against refueling an
aircraft with gas purchased at the corner station for the reasons stated by
Chevron, or believe it would be different in the tank at the airport?
Myself, I always try to run 91 unleaded auto gas in my Rotax 912 ULS because
it's better for the engine. I wish EVERY airport carried 91 auto fuel. I
have personally seen the amount of lead sludge that accumulates in both
Lycoming and Rotax engines running 100LL. I change oil at 20 hrs and
replace plugs after extended periods of using the 100LL. On my trip through
the Dakotas, Montana and Wyoming all I could get at an airport was 100LL. I
currently use stated 10% ethanol blended fuel because that's what is
available and it runs just fine. I'd like it better without the ethanol,
but only because I think the ethanol blending is a bunch of baloney! Roger,
I'll be headed your way this fall. Is the Auto fuel available in Arizona?
Dave
Roger Lee
Posted: Wed Aug 06, 2008 8:56 pm Post subject: Re: Rotax Engines-List: 91 octane and time to be heard |
Hi Dave,
I absolutely want 91 Octane available. Chevron's stance is they refuse to entertain the idea of aircraft using any of their ground based fuel. They are so foolish as to think people don't buy their fuel and use it form a gas station. Some airports in the country actually carry Chevron mogas, but it is usually 87 octane. A few FBO's are just starting to carry the 91 octane. I guess they think if it's not at the airport no one uses their fuel? I have been using 91 octane in three Rotax engines over the years. Yes I have and do at times use 10% ethanol 91 octane. I would like to see 91 octane offered at airports and or some gas stations.
In some of my flying in hotter weather and 3 other people I know, we are having fuel pressure problems that may be related to the different vapor pressures in the ethanol fuel, due to high under the cowl temps. I am in the process of testing as we speak. We had ethanol free fuel here, but it is getting harder to find.
This is a nation wide issue and I would hope that pilots just don't sit and hope the situation will change without their voice. It is getting worse, not better at this point in time. That's why I am hoping that aviators around the country will take just 5 minutes and email some of these people.
Dave,
The ethanol is not put into the fuel until it is time for transport. You may be able to get ethanol free fuel at a fuel supplier and set up an account.
_________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056 |
Float Flyr
Posted: Sat Aug 09, 2008 5:54 am Post subject: Rotax Engines-List: 91 octane and time to be heard |
I take it the best thing to do is to pressure oil companies to produce and
deliver to FBOs a 91 octane unleaded standardized non booze fuel.
I'm in, for all the reasons Chevron stated and a few more as well.
Just send me an E-mail address or even an online petition to both our
governments to have such a fuel available.
Noel
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
