Fuel Sump Leakage
splashlanding(at)comcast.
PostPosted: Sun Aug 10, 2008 9:40 am    Post subject: Fuel Sump Leakage Reply with quote
Hey Thom,
Thanks for the idea about the black particles. I inspected the inside of the tank (I thought thouroughly) after this started happening and didn't notice anything around the strainer, but it may have been purged before I looked.
My sump is the kind that pushes up with a little rod attached to the cup and is spring loaded. It seems the particles are lodging between the two surfaces that seal against each other. It's kind of a pain to remove it each time this happens. Maybe I'll be as lucky as you and this will stop in a short period of time.
I'll keep you posted.
Dale Hackworth
2006 Allegro 2000
N306AD
