hotwheels
Posted: Wed Aug 13, 2008 5:23 pm Post subject: yikes! Subpanel cutouts |
I'm looking at my subpanel next to the Vans plans chapter 41 (hey I'm back in the book again!).
So far, I've trimmed the aft part of the two outboard ribs to allow for adequate EFIS clearance. However, the radio stack seems likely to require reinforced holes (just to the right of the center rib). Are the large cutouts in the plans meant to be a general sort of guideline?
How are radios in the radio stack secured to the subpanel structure?
Are the circular subpanel holes for round steam gauge stuff or for wire routing?
This probably makes perfect sense once you've done it, but there are too many questions to just start whacking away. I'd love to hear what others have done and see some photos if possible.
Thanks in advance for any replies!
Jay
Engine, wiring, and panel stuff... oh my!
Posted: Wed Aug 13, 2008 5:54 pm Post subject: yikes! Subpanel cutouts |
Van's sample is just for reference of different ways of reinforcing
different sizes and shapes of holes. For a radio stack hole, if you
use aluminum angle around the perimeter, with the horizontal angles on
one side and the vertical angles on the other with a rivet holding the
angles to each other in the corners, that seems to be the strongest
format. Then you can make a bracket that ties the radios together or
at least ties the heaviest and/or lowest to one of those angles or
another sub-panel structure. Most radio trays have holes towards the
back that you can put a #6 screw through into a brace, which can be
made out of aluminum angle as well, which can then be bolted/screwed
to one of the angles on the perimeter of the hole.
Most round instruments aren't deep enough to need a hole in the sub-
panel in my experience, but you may have things such as instrument
cooling fans that will have hoses running to the back of the radio
stack, and you will certainly have a lot of cables running between the
radio stack and the other instruments, not to mention all of the wires
for engine monitoring, electrical buss(es), pitot and static lines,
remote magnetometers and ahrs units, etc. Find out how many things
you have to run, then make at least double the number of holes you
need to run them. I like to use 3/4" holes with snap bushings as much
as possible, often with nutplates to screw cushion clamps onto for
supporting wiring runs where needed around the subpanel, usually along
the bottom.
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
Cell: 352-427-0285
Fax: 815-377-3694
On Aug 13, 2008, at 9:22 PM, Jay Brinkmeyer wrote:
guideline?
wire routing?
Jay
