JetPilot
Posted: Thu Aug 14, 2008 10:03 am Post subject: Which Expoy Primer and Structural Epoxy Should I Use ??? |
What is the best epoxy primer to use on and inside the Aluminum wing spars on the Kitfox ? Also does the same epoxy primer work well on 4130 Steel ?
Secondly, what is the strongest structural epoxy I can get for the Kitfox ?
Kolb MK-III Xtra, 912-S |
n85ae
Posted: Thu Aug 14, 2008 1:21 pm Post subject: Re: Which Expoy Primer and Structural Epoxy Should I Use ??? |
Polyfiber epoxy primer is very good. 3M 2216, or Hysol are both very good
adhesives. The wing ribs are bonded using this with cotton flox.
Jeff
