espuny(at)terra.com.br Guest
				 Posted: Mon Aug 18, 2008 5:25 pm    Post subject: RES: Re: Ethanol - facts and no myths or fiction |
				I think that while distiling you should be testing density to "cut" it at the right time and not get too much water inside, no need to worry about the proper temp, just boil it.
 But I'm wondering if in my case wouldn't it be safer to run an aero engine certified for AVGAS, and I could do the maintainance myself if installed in a experimental plane ("myself" means not enriching the certified hangars and paying the right price for a good and honest mechanic service).
 It's more confortable for me , once I'm looking for my plane/engine set. It'd be hard if I yet had it inside the hangar.
 AVGAS is the only option we have that may not change, as it's an international standard to be used everywhere by pilots from any country.
 -----Mensagem original-----
 De: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] Em nome de Noel Loveys
 Enviada em: segunda-feira, 18 de agosto de 2008 21:08
 Para: kitfox-list(at)matronics.com
 Assunto: RE: Re: Ethanol - facts and no myths or fiction
 I have been told 87 not sure whether that is RON or MON
 About the water/eth it will not burn... unless you distil it again.  Espuny could do that and burn the recovered eth in his car in effect lowering the cost of his flying fuel.  It's been a long time since I distilled alcohol ( all the way back to high school) but I think it distils at 80C, standard pressure.
 Noel
  |  | - The Matronics Kitfox-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
