dlm46007(at)cox.net Guest
Posted: Fri Aug 15, 2008 12:33 pm Post subject: tire air pressure checks |
How have flying RV10s handled the tire pressure checks without removing a portion of the wheel pant?
Posted: Fri Aug 15, 2008 1:58 pm Post subject: tire air pressure checks |
We've drilled a 2" hole in the wheel pant (mains only) and put a Cirrus (blasphemous word, I know) plastic plug in there. With that plug removed you can get a gauge with a 45 degree head onto the valve stem, but you have to leave the cap off if you want to be able to do that.
Jesse Saint
Saint Aviation, Inc.
Cell: 352-427-0285
Fax: 815-377-3694
On Aug 15, 2008, at 4:31 PM, David McNeill wrote:
| Quote: | How have flying RV10s handled the tire pressure checks without removing a portion of the wheel pant?
carl.froehlich(at)cox.net Guest
Posted: Fri Aug 15, 2008 2:59 pm Post subject: tire air pressure checks |
Wasn’t there a thread awhile back about replacing the standard inner tubes with ones that have the a valve stem with a 90 degree bend such that it points perpendicular to the wheel? This is what I have on my 8A. It allows you to attach a valve extension through a small door in the wheel pant. I put a spring loaded door (ACS catalog item) on the wheel pants and carry in the plane an extension made from four Wal-Mart valve stem extensions screwed together.
Carl Froehlich
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jesse Saint
Sent: Friday, August 15, 2008 5:57 PM
Subject: Re: tire air pressure checks
Jesse Saint
Cell: 352-427-0285
Fax: 815-377-3694
| Quote: | | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-Listhref="http://forums.matronics.com">http://forums.matronics.comhref="http://www.matronics.com/contribution">http://www.matronics.com/contribution |
| Quote: | | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List | 0 | Quote: | | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List | 1 | Quote: | | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List | 2 | Quote: | | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List | 3 | Quote: | | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List | 4 | Quote: | | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List | 5 | Quote: | | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List | 6 | Quote: | | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List | 7 | Quote: | | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List | 8 | Quote: | | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List | 9 | Quote: | | href="http://forums.matronics.com">http://forums.matronics.com | 0 | Quote: | | href="http://forums.matronics.com">http://forums.matronics.com | 1 | Quote: | | href="http://forums.matronics.com">http://forums.matronics.com | 2 | Quote: | | href="http://forums.matronics.com">http://forums.matronics.com | 3 | Quote: | | href="http://forums.matronics.com">http://forums.matronics.com | 4
Posted: Fri Aug 15, 2008 3:40 pm Post subject: tire air pressure checks |
I don't know about the -8A, buy on the -10 you would need about a 45 degree angle bend to work with the main wheel.
Jesse Saint
Cell: 352-427-0285
Fax: 815-377-3694
On Aug 15, 2008, at 6:57 PM, Carl Froehlich wrote:
| Quote: | Wasn’t there a thread awhile back about replacing the standard inner tubes with ones that have the a valve stem with a 90 degree bend such that it points perpendicular to the wheel? This is what I have on my 8A. It allows you to attach a valve extension through a small door in the wheel pant. I put a spring loaded door (ACS catalog item) on the wheel pants and carry in the plane an extension made from four Wal-Mart valve stem extensions screwed together.
Carl Froehlich
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of Jesse Saint
Jesse Saint
Cell: 352-427-0285
Fax: 815-377-3694
012345678901234
5
