Is a quart enough sealant for the fuel tanks?
rleffler
PostPosted: Sun Aug 17, 2008 4:57 am    Post subject: Is a quart enough sealant for the fuel tanks? Reply with quote
The subject pretty much says it all. Van's online catalog states that the quart is ample for a 7/8, but doesn't mention the 10. I'm just getting ready to start the tanks and wanted to ensure I have enough sealant on hand.
Bob Leffler
N410BL - Phase I
http://mykitlog.com/rleffler
carl.froehlich(at)cox.net
PostPosted: Sun Aug 17, 2008 5:31 am    Post subject: Is a quart enough sealant for the fuel tanks? Reply with quote
Buy two quarts. You'll need some later on for odds and ends anyway. Store
what you don't use in the freezer.
Carl Froehlich
RV-8A (450 hrs)
RV-10 (fuselage)
Tim Olson
PostPosted: Sun Aug 17, 2008 6:02 am    Post subject: Is a quart enough sealant for the fuel tanks? Reply with quote
I'd get 2....and not attempt to go to sparingly on the proseeal.
Fill in good under the ribs, and even smooth in faired in
fillets around the rib to skin joints too. It's a job that
isn't that bad to do, but that you don't want to do twice or
have to fix later. You can always use it in other places
later. I still have some in my quart kept in the freezer
and I wouldn't hesitate to use it for non-fuel-tank things
still today.
-------- Bob Leffler N410BL - Wings RV-10 #40684
http://forums.matronics.com/viewtopic.php?p=199059#199059
pascal(at)rv10builder.net
PostPosted: Sun Aug 17, 2008 3:41 pm    Post subject: Is a quart enough sealant for the fuel tanks? Reply with quote
Can be done easily. I did it and had/have plenty left over.
The secret is don't put on more than is needed. I took my time and did every
single rivet with little excess using a syringe, toothpick and q-tip
(without the cotton swab).
There is a great write up on vansairforce search for it under "prosealing"
otherwise I put a copy of the document on my site
http://rv10builder.net/test.aspx
Also if you're interested in a few pictures I have a slide show of the
process with a review as I went along Section 18.
http://rv10builder.net/sect18.aspx
Pascal
Sent: Sunday, August 17, 2008 5:57 AM
Subject: Is a quart enough sealant for the fuel tanks?
hand.
Bob Leffler
N410BL - Wings
RV-10 #40684
