larry huntley
Posted: Sat Aug 16, 2008 5:01 pm Post subject: Model 4 gear |
Does anyone have a set of model 4 main gear they would sell? Hoping someone changed out to Grove gear and has some leftovers. Larry
Larry Huntley 4-1200 Soob
asq(at)roadrunner.com (asq(at)roadrunner.com)
Checked by AVG - http://www.avg.com [b]
_________________ Larry Huntley,Dundee,NY
Kitfox 4-1200 N234EE
EA81,AMAX Redrive Warp 3 blade |
larry huntley
Posted: Sat Aug 16, 2008 5:03 pm Post subject: Model 4 gear |
Should have mentioned,don't need the wheels and Checked by AVG - http://www.avg.com [b]
lcfitt(at)sbcglobal.net Guest
Posted: Sat Aug 16, 2008 6:13 pm Post subject: Model 4 gear |
Larry,
My new - 1992 - kit came with tube gear and I will be using the taller
cabane style gear. Can you handle b;ue powder coat? Contact me off list.
Lowell
gary.algate(at)sandvik.co Guest
Posted: Sun Aug 17, 2008 3:26 pm Post subject: Model 4 gear |
Try Brian Morrisette (Sudbury, Canada) he is finishing a Speedster and has purchased the Grove gear. (Brian monitors the list)
Gary
Gary Algate
Classic 4 / Jab2200
Office Phone: +61 8 8276 7655
This e-mail is confidential and it is intended only for the addressees. Any review, dissemination, distribution, or copying of this message by persons or entities other than the intended recipient is prohibited. If you have received this e-mail in error, kindly notify us immediately by telephone or e-mail and delete the message from your system. The sender does not accept liability for any errors or omissions in the contents of this message which may arise as a result of the e-mail transmission.
"Larry Huntley" <asq(at)roadrunner.com>
Sent by: owner-kitfox-list-server(at)matronics.com
17/08/2008 10:40 AM
Please respond to
kitfox-list(at)matronics.com To
<kitfox-list(at)matronics.com> cc
Subject
Model 4 gear
[url=Arial]asq(at)roadrunner.com[/url]
-Matt Dralle, List Admin.
larry huntley
Posted: Mon Aug 18, 2008 2:38 am Post subject: Model 4 gear |
Good morning Folks,
I thank you all for your responses to my request for kitfox gear. I will be picking up a set nearby soon. I appreciate that so many responded both on and off list to help me out of dilemma. I had a fuel problem and had to land ( semi-controlled crash) in a very short hayfield with a very steep upslope. A self induced groundloop wiped out the gear ,but kept me out of the trees. Fuselage was bent at the gear fittings ,but won't take a lot to repair. Needs a bit of new tubing and a lot of time. It is all stripped down now and rhe fuselage is ready to go into the rotissiare . Repairs will have to wait til winter. Have to finish up a couple of other projects first.
