Lew Gallagher
Posted: Mon Aug 18, 2008 6:22 am Post subject: center of gravity |
Hey Guys,
I've been wondering about this for awhile and Doug's "I have the Airflow system & my CG is 108.4" on the AC thread prompted me to just
ask:
Where is this 108.4" measured from? Probably obvious, but I haven't found it yet, and other general literature on COG talks about a reference point somewhere in front of the plane.
It seems to be a very critical measurement. So far, I'm still head-down-building, but getting closer to needing to know stuff like this.
Later, - Lew
_________________ non-pilot
crazy about building
NOW OFICIALLY BUILDER #40549
Fly off completed ! |
bcondrey
Posted: Mon Aug 18, 2008 7:44 am Post subject: center of gravity |
Lew,
Here's the info I've got at hand:
Datum: 99.44" forward of the wing leading edge
Allowable CG range: 107.84" - 116.24" (15-30% of wing chord)
Front seats: 114.58"
Rear seats: 151.26"
Fuel: 108.9"
Baggage: 173.5"
Main wheel (right): 124.44"
Main wheel (left): 124.31"
Nose wheel: 50.44"
N442PM (flying)
AV8ORJWC
Posted: Mon Aug 18, 2008 8:51 am Post subject: center of gravity |
Another way is that your CG (empty) is 8.96" aft of the leading edge of
your wings (in theory). The usable CG is a dynamic which moves forward
and aft from that imaginary point based on your current Load
considerations. Tim did a great job talking about aft of Empty CG and
Forward of Empty CG changes to the flight characteristics in your hand.
Flying forward of 15% or Aft of 30% of the MAC is "Not a good thing".
Sean Tucker safely crashed aircraft #3 when he lost the prop and hub
which radically changed the Aft CG more than 8" beyond the maximum. Oh
by the way, he was on the ground 53 seconds later and he had onboard
video of it. Do not try this at home.
Many builders relocate or locate components with little regard for their
impact on the empty CG. A few builders have announced that they have a
left of center/right of center change as well. One builder took
exception to why anyone would want to relocate avionics off the panel
and remotely mount them. It is all about manipulation of the final
empty CG. VAN has designed us a conservative and flexible platform.
Those flying can comment more meaningfully on this important issue to
insurance rates and flying pleasure.
YMMV
John Cox
#40600
jcumins(at)jcis.net Guest
Posted: Mon Aug 18, 2008 9:56 am Post subject: center of gravity |
Since you brought up MAC you might need to explain it in better detail and
in a e-mail that might be tuff. OK pulling out the old Flight engineer hat
for this one. MAC stands for Mean Aero dynamic cord and when referenced, cg
is usually a % of the mac.
In flying the c-5 for almost 15 yrs our cg ran from 41% of mac for aft cg to
29% of mac for fwd cg. The airplane empty an 397,000 lbs was usually at 39%
of mac. And remember this does not include any fuel, crew, baggage, or
cargo.
It really is just a math calculation to figure it out. WG is still based on
weight x arm for the moment then added together and referenced to the
appropriate table to insure your in the cg envelope for your flight
conditions.
I have nod sat down and plotted the cg envelope for the -10 but I will and I
will make a spread sheet and reference diagram that I will share with
everyone.
This brings up another issue I have seen on the list about when people weigh
there plane. I think people do not understand what is required to get the
basic airplane weight.
The basic weight of the plane, Is the airplane with zero fuel, Engine with
full oil as called out in the engines service manual. It the manufacture
states 12 qts then there needs to be 12 qts in the oil system. No
accessories in the plane, no head sets, tow bars, maps, or any pilots
accessories, just the basic airplane.
The airplane needs to be perfectly level on both axes vertical and
horizontal, this is very critical to get accurate weights. The manufactures
maintenance manual will give you the level points.
Once these conditions are met then you can get a good weight and figure out
the arm and moments then your basic empty weight cg.
| Quote: | From what I have seen with the large variance of numbers that have been
posted here, It looks to me there needs to be some re-weighting that needs
to be done very carefully.
Ok that's my 2 cents worth.
John G. Cumins
#40864 Virtal Stab done starting rudder
Your Total Technology Solution Provider
AV8ORJWC
Posted: Mon Aug 18, 2008 11:34 am Post subject: center of gravity |
The Excel spreadsheet has been done and is in the Matronics archives
(Tim and I have them as well). The weighing process is as you describe
but many builders do not achieve balanced nirvana on the vertical and
horizontal. Many are casual with the scale accuracy as well. Many weigh
the aircraft Sans wheel skirts and fairings to get a beginning weight
for the DAR. Those items come later in the Phase One completion (and
may never be updated). VAN has designed the airfoil of the wing and
established the minimum and maximum MAC as you describe. Rob Hickman's
AFS Efis even allows a graphic presentation for up to the minute/up to
the flight Weight and Balance changes.
The large variance of numbers is due to/but not limited to avionics
choices, trim servos, body putty on the composite pieces, size of
battery and quality of fire suppression and noise suppression materials.
All that up to each builder.
What you left off is the aircraft being weighed needs to be out of the
wind and elements to truly get a correct reading. If a DAR blows off
the importance of an accurate list or proper weighing it is in the hands
of the individual builder. If we are building... we should sure know
what M.A.C. is.
Note: When buying an aircraft. Have your Pre-purchase inspection
include a Weight and Balance as part of the agreement. Takeoff 5% of
the price for every 1% of weight variance and watch the seller squirm.
If the Gross Weight is over the VAN approved RV-10 weight, take another
5% for every 1% of weight that is over limit without full FAA spin
testing. Watch how quick the ink erasers come out. Though Dan
Checkoway's weight table has fewer submittals than mine, his is easy to
read and understand.
