richard.goode(at)russiana Guest
Posted: Tue Aug 19, 2008 7:46 am Post subject: Certification |
Certification
This is not a simple issue, and to respond to recent postings:
Type Certificates are not something that can be "provided". You need to start with an aeroplane that has been designed according to a design code to obtain Type Certification, and, effectively, it is impossible to do this retrospectively.
In terms of the popular Russian light aircraft, the 50/52/55 were designed to a very high standard, but a military design code.
The 18T was designed to a Russian civil design code - but with which there are no comparable codes in the West.
The US has FAR 23, and Europe has had JAR 23, which are almost identical. Following these, some ten years ago, Russia established AR 23, which is paragraph for paragraph the same, although in some areas, the Russian standard in more demanding.
HOWEVER, given the lack of bilateral agreements between Russia and the West, the Russian Type Certification is not automatically accepted in the West.
Also, the cost within Russia of obtaining Type Certification is so big that it effectively deters anyone from undertaking it.
However the Su-29 and 31; Yak-54 have obtained AR 23 Full Certification.
In Western countries, Lithuania has gone through a process of Type Certification for Yak-54, and Hungary has Type Certificated the Sukhois and the Yak-18T. The view of EASA has been that Hungarian certifications were not sufficiently thorough for EASA to automatically accept them, but EASA felt that the Sukhois / Yak-54 / 18T were all aeroplanes that should be Type Certificated, and therefore proposed a "short cut" certification process to go from the historical Russian code (for 18T) and AR 23, (for Sukhois and Yak-54). EASA emphasised that this would be a genuine short cut; would be genuinely cheap; most of the work would be done by themselves. However none of the Russians would agree to cooperate and provide the data/flight test reports etc that would be needed.
Very fortunately EASA took a very sensible view and did not, as they could have, relegate all these aeroplanes into "Annexe 2" (see below), and on an initial basis have given them EASA "Permits to Fly".
The practicality is that these planes can fly without effective restrictions throughout Europe; be maintained anywhere within Europe etc.
It is now the intension of EASA to change from Permits to Fly (which had always been intended as a temporary category) into long term Restricted Certificates of Airworthiness. Hopefully this process will begin in the next few months.
Hans Oortman is wrong to say that Yak-52 and 50 are "on the EASA list". Sure they are on an EASA list - which is their Annexe 2. Annexe 2 is for aircraft that are NOT in the jurisdiction of EASA, and this includes a huge spectrum of aircraft such as Home-built; Warbirds; aircraft produced before Type Certified standards AND Yak-50 and 52.
The whole point of Annexe 2 is that these aeroplanes are not the responsibility of EASA, but are handled by the local National Aviation Authority in each country. Fortunately as we know only to well, there is no uniformity amongst European countries as to how this should be handled.
So, if it is a type that currently gets an EASA "Permit to Fly" like a Sukhoi/18T etc, no problem to bring one into Europe.
If not, today you have the possibility of Russian registration, or you have a Restricted Certificate from another country, coupled with a "Over-Fly" Permission from your own, or you try to get it accepted by your own NAA!
Hope that this helps.
Richard Goode Aerobatics
Rhodds Farm
Lyonshall
Herefordshire
HR5 3LW
United Kingdom
Tel: +44 (0) 1544 340 120
Fax: +44 (0) 1544 340 129
www.russianaeros.com
pa3arw(at)euronet.nl Guest
Posted: Tue Aug 19, 2008 11:18 am Post subject: Certification |
It is the Annexe 2 list which I meant…
I have been told by our CAA that eventually, what ever that means, we will have a category ( the legal term I believe is because of grandfathers rights…) in Holland where those aircraft will fit….the problem is…nobody told us when….
Hans
Van: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] Namens Richard Goode
Verzonden: dinsdag 19 augustus 2008 17:19
Aan: YAK USA LIST
Onderwerp: Certification
[b]Certification [/b]
Rhodds Farm
Lyonshall
Herefordshire
HR5 3LW
United Kingdom
| Quote: | | http://www.matronics.com/Navigator?Yak-List | 0123456789
Posted: Tue Aug 19, 2008 11:55 pm Post subject: Certification |
Hans-the problem with Annexe 2 is that EASA has no involvment with it,so the individual NAA's can make whatever rules they like in each country,and it is much easier to say "no" than it is to take the responsibility of allowing strange aircraft to fly!
Richard
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
United Kingdom
Tel: +44 (0) 1544 340120
Fax: +44 (0) 1544 340129
Posted: Wed Aug 20, 2008 1:03 am Post subject: Certification |
Richard,
I understand your point. As fars as my intel is concerned the idea is (for Holland that is…) to allow ex warbirds including Yaks, Sukhois etc to register in the experimental class where by they will impose a maximum number of flight hours of 100 per year and maintenance should be done by authorized technicians for those specific planes. But this is 8 months ago, I don’t know what the latest status is. Quite frankly I have given up on this matter, at the moment there are about 6 Yaks flying here. If they want to ground those w’ll see what happens. By that time I will have left Netherlands already…I am fed up with it.
I hear what you say…civil employees don’t like to take responsibilities and certainly not here.
Fly safe!
Hans Oortman, MBA, Ph.D.
CEO
STN BV
Verzonden: woensdag 20 augustus 2008 9:54
Aan: yak-list(at)matronics.com
Onderwerp: Re: Yak-List: Certification
Richard
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
United Kingdom
Posted: Wed Aug 20, 2008 3:48 am Post subject: Certification |
Hans,
If you're planning on leaving Holland, you're always welcome here in the US. Bring your Yak. There is always room for one more (as my mom always said).
Dennis
cjpilot710(at)aol.com Guest
Posted: Wed Aug 20, 2008 6:22 am Post subject: Certification |
I live on an airpark NW of Daytona Beach. Half of our residents are foreign
nationals. English with the exception of one German. On the field is a DH
Moth on floats, Chipmunk (very original) and a Jungmiester. We see most of
them (the foreigners) during the cold months, but they are more welcome than
most.
Two mile to the SW is a another private field. 4 mile to the NW is another
airpark with a hard surface runway. 5NE is another private strip. 8 miles E
is another private strip. All these are active fields.
I am willing to bet you will not find that anyplace in the world.
In a message dated 8/20/2008 7:49:03 A.M. Eastern Daylight Time,
dsavarese0812(at)bellsouth.net writes:
Hans,
randmyak52(at)bellsouth.n Guest
Posted: Wed Aug 20, 2008 9:32 am Post subject: Certification |
Sounds like you should move Pappy, too damn much traffic!
Lefty
