dlm46007(at)cox.net Guest
Posted: Fri Aug 22, 2008 5:03 am Post subject: tip on wing construction |
The bellcrank and other inspeciton panels have #6 standard nutplates at the corners. You might consider replacing these with single wing nutplates. When the standard nutplate gets damaged there , the rivet on one end is under the skin there. It changes an easy repair to one which requires some finesse. BTDT.
MauleDriver(at)nc.rr.com Guest
Posted: Fri Aug 22, 2008 9:18 am Post subject: tip on wing construction |
Interesting... just as I finish putting the skin over them. Of course, it shouldn't be a problem as long as you don't damage them - so curious minds want to know, what happened? Just a mis-thread with a power driver or ?
David McNeill wrote: [quote] The bellcrank and other inspeciton panels have #6 standard nutplates at the corners. You might consider replacing these with single wing nutplates. When the standard nutplate gets damaged there , the rivet on one end is under the skin there. It changes an easy repair to one which requires some finesse. BTDT.
| [b]
Posted: Fri Aug 22, 2008 2:24 pm Post subject: tip on wing construction |
paint shop tried to start the screw with power screw driver
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of MauleDriver
Sent: Friday, August 22, 2008 10:17 AM
Subject: Re: tip on wing construction
