corbob13
Posted: Fri Aug 22, 2008 10:00 am Post subject: Fuel tank shake |
Guys,
I have a question regarding the shaking of the fuel tank/instrument panel in my model II. If it weren't for the fact it made my compass drift unreliable I wouldn't care about it. The problem is that through all phases of flight I have a really low frequency shake that has just enough amplitude so that my compass won't settle on a heading.
Has anyone else had this problem? Any ideas?
_________________ Cory
N903DB
Kitfox Model II, Rotax 582 |
matronics(at)bob.brennan. Guest
Posted: Fri Aug 22, 2008 4:48 pm Post subject: Fuel tank shake |
What prop? Possibly unbalanced?? How are the engine mounts? The panel
mounts?
Bob Brennan - N717GB
1991 UK Model 2 ELSA Kitfox
Rotax 582 with 3 blade prop
Wrightsville Pa
kitfox555(at)sbcglobal.ne Guest
Posted: Fri Aug 22, 2008 7:20 pm Post subject: Fuel tank shake |
You know I had this happen to me and the problem was one of the props was out a couple of degrees. I would check each prop for pitch and 1/8 alignment try to make all same rpms should be about 6200-6250 static, try let us know Jerry
corbob13 <corbob13(at)netnet.net> wrote: [quote]--> Kitfox-List message posted by: "corbob13"
Guys,
Cory
N903DB
Kitfox Model II, Rotax [quote][b]
corbob13
Posted: Tue Aug 26, 2008 9:34 am Post subject: Re: Fuel tank shake |
I finally got out flying and looked things over before flight. I had accumulated quite a few bugs on the prop and cleaned them off, thinking they could have been a contributor; no luck. The engine mounts seem fine and I don't think it would be panel mounts since the entire tank shakes a bit, not just the panel (the compass is mounted on top of the panel/tank not in the panel). It's not the prop setting since I have a two blade fixed pitch wood prop, 68x36. It could be a balance issue, I can have that checked next week when it goes in for annual. I also have a PXP 71x37 prop that came with the plane that I wanted to try, maybe this is my excuse to change it.
N903DB
propellerdesign(at)tele2. Guest
Posted: Tue Aug 26, 2008 10:39 am Post subject: Fuel tank shake |
How do you leave the propeller when hangared?
Jan
lcfitt(at)sbcglobal.net Guest
Posted: Tue Aug 26, 2008 11:28 am Post subject: Fuel tank shake |
Cory,
I am definitely not an expert on this, but I think the prop might just be
the problem. There have been numerous posts on the list regarding the
smoothness of the three bladed prop vs. the two blade. I just had a
conversation with a friend this morning that mentioned that the Rans LSA
product has a two blade prop and the customers don't like it and it is
hurting sales. For them, as I understand it, it is more of a performance
issue, but in a certified LSA once the design is certified, that's it - no
changing out the props.
Lowell
corbob13
Posted: Tue Aug 26, 2008 6:39 pm Post subject: Re: Fuel tank shake |
It sounds like other suspect the prop, which does seem most likely. Jan, I think I see where you're getting with your question, and to be honest I leave it where ever it stops. Before I bought the plane it sat unused for a while, and the prop may have been in a horizontal orientation (if I understand where you're headed). I'll follow up if I find a solution. Thanks again.
N903DB
Posted: Tue Aug 26, 2008 9:53 pm Post subject: Fuel tank shake |
Cory
You are on something, I've seen it before and it really make a difference
where you leave the 2 bladed wooden prop, it can be other factors though.
Also, a wooden fixed pitch prop can have different angles on both blades if
poorly made.
A 3 bladed is said to be smoother on some engines, but how to store it
horizontal? put the plane on the nose in hangar?
Jan
