Lenny Iszak
Posted: Mon Aug 25, 2008 6:19 pm Post subject: Old fuse, new plans... |
I've been scratching my had trying to figure out how am I going to screw the 6D bulkhead fittings into a 1 inch hole , where the fuel line exits the fuselage at the wing root.
I just looked at the plans on Tim's site and as it turns out I have the Revision#2 plans and a Rev #0 fuselage. Even my Fuel selector bracket is different.
Do any of you know why this was changed?
The Rev 2 plans also show an extension rod for the fuel selector.
I guess at this point I should just print Tim's plans and use those.
Lenny
#40803
rene(at)felker.com Guest
Posted: Mon Aug 25, 2008 6:33 pm Post subject: Old fuse, new plans... |
In my plans, the fuel line is one piece from the tank to the fuel valve. I
used a rubber grommet in the 1 inch hole.
Rene'
801-721-6080
Posted: Tue Aug 26, 2008 3:58 am Post subject: Old fuse, new plans... |
I have Rev 1 plans that shows a 1 piece fuel line. I guess I have a Rev
0 QB fuse. In any case, I bought some extra fittings and used some
large aluminum washers to hold the fittings in the large tunnel hole.
Just couldn't make sense out of the single piece fuel line and the
Andair valve I ended up using.
Bill Watson
Lenny Iszak wrote:
Lenny
#40803
http://forums.matronics.com/viewtopic.php?p 0594#200594
pascal(at)rv10builder.net Guest
Posted: Tue Aug 26, 2008 6:53 am Post subject: Old fuse, new plans... |
Lenny;
I would discourage you copying Tim's plans that are 2 revisions behind
yours. I would call Van's and ask for insight. You should have all the parts
to go with the plans, if you don't Van's will send you what you are missing.
Last week I had an issue with a piece that wasn't on the packing list at
all, Van's sent me the part without question saying I should have it and
it's on the way. They have been excellent with customer support and tech
support through my build.
Pascal
Sent: Monday, August 25, 2008 7:19 PM
Subject: Old fuse, new plans...
different.
Lenny
#40803
wcurtis(at)nerv10.com Guest
Posted: Tue Aug 26, 2008 7:32 am Post subject: Old fuse, new plans... |
It sounds like the new revision plans are doing what many builders (Bob Newman and me) have done and installed bulkhead fittings at the fuselage instead of a continuous tubing run from selector to tank. I'd really like to see what other changes they have instituted. Per the previous message from Bob, you probably want to use a large rubber grommet rather than solid washers as per AC 43, you do not want tubing between bulkheads without some type of strain relief.
http://www.tcwtech.com/RV-10%20construction%20project.htm
William
http://nerv10.com/wcurtis/
msausen
Posted: Tue Aug 26, 2008 8:43 am Post subject: Old fuse, new plans... |
That's funny, I had no idea they did that but it's exactly what I ended up doing. I used a rubber grommet and then captured it between a couple fender washers to make sure it doesn't go anywhere.
http://www.mykitlog.com/users/display_log.php?user=msausen&project 2&category=1703&log=57694&row
Michael
Lenny Iszak
Posted: Tue Aug 26, 2008 6:43 pm Post subject: Re: Old fuse, new plans... |
William,
I like the idea of using the bushings because I want to run flexible fuel lines to the wing root.
Do you know if anyone sells them, or do i have to make my own?
Lenny
#40803
Posted: Wed Aug 27, 2008 3:34 am Post subject: Old fuse, new plans... |
| Quote: | I like the idea of using the bushings because I want to run flexible fuel lines to the wing root.
Not that I'm aware of but I guess you can ask Bob Newman for the one he made and are not using because he is using the rubber washers.
William
