sarg314(at)comcast.net Guest
Posted: Wed Aug 27, 2008 8:52 pm Post subject: dual brakes vs. single |
I talked with Ken at Van's today about problems routing brake lines for
my dual brakes (my own fault mostly, for the way I organized things on
the firewall). He observed that he thinks dual brakes aren't worth it.
It's a few pounds of weight that almost never gives any benefit. He
says he's taking the dual brakes out of his plane soon.
Do those of you who have dual brakes ever really use the right side? I
thought it would be helpful if I ever took a CFI up with me. However,
removing them now would greatly simplify my brake routing problems.
I've just about decided to tear out the right side.
Thanks for any opions.
Tom Sargent, RV-6A.
| - The Matronics RV-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
sportav8r(at)gmail.com Guest
Posted: Thu Aug 28, 2008 4:14 am Post subject: dual brakes vs. single |
Removing my pax-side brakes is on my to-do list, Tom. Never used 'em once in 10 years flying. I have parking brake valve in case I ever need to hand prop (or just have pax sit on the left for the time being and hold brakes.) They add weight, expense (probably too late to recoup that) and they, alone, are the source of the only seepage in the whole system. Mine should be on ebay within a month
I don't think a CFI would be anxious about no brakes on his side in a nosewheel aircraft.
-Bill Boyd RV-6A 710 hrs
On Thu, Aug 28, 2008 at 12:51 AM, tom sargent <sarg314(at)comcast.net (sarg314(at)comcast.net)> wrote:
[quote]--> RV-List message posted by: tom sargent <sarg314(at)comcast.net (sarg314(at)comcast.net)>
I talked with Ken at Van's today about problems routing brake lines for my dual brakes (my own fault mostly, for the way I organized things on the firewall). He observed that he thinks dual brakes aren't worth it. It's a few pounds of weight that almost never gives any benefit. He says he's taking the dual brakes out of his plane soon.
Do those of you who have dual brakes ever really use the right side? I thought it would be helpful if I ever took a CFI up with me. However, removing them now would greatly simplify my brake routing problems. I've just about decided to tear out the right side.
Tom Sargent, RV-6A.
_= - MATRONICS WEB FORUMS -
sbuc(at)hiwaay.net Guest
Posted: Thu Aug 28, 2008 7:03 am Post subject: dual brakes vs. single |
I was assuming the person getting a BFR or transition training would know how to taxi (!) but taking off and landing a tailwheel aircraft looks a bit more risky and complicated than same in a trigear. I've only done it a half-dozen times with an instructor, and that many more with Mike Segar, so I admit my opinion isn't worth much. Is it all rudder and no brakes until you get to the pump, in a taildragger? Shows you what I know...
I was taking my own situation into account: need BFR every 2 years in a nosewheel RV that I have 700 hours in. CFI not likely to feel anxious about me having the only brakes in the aircraft. Pit me in a taildragger for a BFR and suddenly his comfort level is very different, right?
-Bill
On Thu, Aug 28, 2008 at 8:49 AM, Sam Buchanan <sbuc(at)hiwaay.net (sbuc(at)hiwaay.net)> wrote:
[quote] --> RV-List message posted by: Sam Buchanan <sbuc(at)hiwaay.net (sbuc(at)hiwaay.net)>
Bill Boyd wrote:
Quote: | I don't think a CFI would be anxious about no brakes on his side in a
nosewheel aircraft.
I would think a CFI would be much more concerned about RH brakes in a nosewheel aircraft than in a tailwheel plane. Brakes can be pretty important for steering an -A model but are only needed in a tailwheeler to avoid taxiing into the gas pump.
Sam Buchanan
panamared5(at)brier.net Guest
Posted: Thu Aug 28, 2008 7:29 am Post subject: dual brakes vs. single |
Quote: | I was taking my own situation into account: need BFR every 2 years
different, right?
I have a taildragger, no right hand brakes. When I do a Flight
Review, there is no need for the CFI to ever touch the controls. The
CFIs that I fly with are not even taildragger qualified.
Speaking of a Flight Review, if all you have is a single seat
aircraft such as the RV3, I assume one has to do the Flight Review in
a different aircraft with at least two seats? Now if the two seat
aircraft is an RV4/8, do you have to have any controls for the CFI at all?
RV6 "Wicked Witch of the West"
Posted: Thu Aug 28, 2008 7:47 am Post subject: dual brakes vs. single |
Speaking of which, I need a BFR, and would appreciate recopmmendations for someone local to the LWB area who is comfortable giving one in an RV. Thanks, Bob.
-Bill B
On Thu, Aug 28, 2008 at 12:25 PM, Bob <panamared5(at)brier.net (panamared5(at)brier.net)> wrote:
[quote]--> RV-List message posted by: Bob <panamared5(at)brier.net (panamared5(at)brier.net)>
Quote: | I was taking my own situation into account: need BFR every 2 years in a nosewheel RV that I have 700 hours in. CFI not likely to feel anxious about me having the only brakes in the aircraft. Pit me in a taildragger for a BFR and suddenly his comfort level is very different, right?
I have a taildragger, no right hand brakes. When I do a Flight Review, there is no need for the CFI to ever touch the controls. The CFIs that I fly with are not even taildragger qualified.
Speaking of a Flight Review, if all you have is a single seat aircraft such as the RV3, I assume one has to do the Flight Review in a different aircraft with at least two seats? Now if the two seat aircraft is an RV4/8, do you have to have any controls for the CFI at all?
n343fd(at)yahoo.com Guest
Posted: Thu Aug 28, 2008 8:03 am Post subject: dual brakes vs. single |
Tom
I am not as experienced as 99% of the people here but I have had occasion to use my right side brakes several times. Twice when the wind was gusting to 30+ knots (I seem to remember it closer to 40 but that seems high. Any way it was out at KIFP). There was just no way to get out of the plane without having the wind pushing it all over the place (granted someone with more flight time might know a way). My wife got on the brakes and controls and presto problem solved ... well sort of the wind was still causing trouble but I got the plane tied down. Then twice on a hill she helped out. The hill I could have used my parking brake but in the wind I really needed someone on and off the brakes several times. Granted my plane is a not a 6A but I tend to think most CFI's would want access to the breaking system.
Again I am no expert or authority in any way I have low time in an RV (closing in on 100 hr in my 6). Just letting ya know that I was glad I had my pax brakes on at least 2 occasions.
Mike D
N64GH - RV6
FREEDOM IS NOT FREE - THANK THE AMERICAN SOLDIER FOR YOURS!
Posted: Thu Aug 28, 2008 12:34 pm Post subject: dual brakes vs. single |
If I'm not mistaken, the FAA changed the rules a few years ago & 'full
dual controls' are now legally required for instruction, including
flight reviews. Having said that, none of the CFI's that I know pay any
attention to the rule, even in TW planes, if they know you & your
abilities. If someone lives in an area where all the CFI's are koolaid
drinking nazi's, it might be worth some research.
Bill Boyd wrote:
Quote: | Removing my pax-side brakes is on my to-do list, Tom. Never used 'em
nosewheel aircraft.
Tom Sargent, RV-6A.
ronlee(at)pcisys.net Guest
Seems like a lot of anguish over just a few pounds.
Ron Lee
wskimike(at)mchsi.com Guest
Posted: Thu Aug 28, 2008 3:52 pm Post subject: dual brakes vs. single |
I don't think you understood about the CFI. If you plan to get a certification in the aircraft, the rule states dual controls. This includes brakes.
jsflyrv(at)verizon.net Guest
Posted: Thu Aug 28, 2008 6:32 pm Post subject: dual brakes vs. single |
YES
> different, right?
all?
Kellym
Posted: Thu Aug 28, 2008 7:16 pm Post subject: dual brakes vs. single |
Sorry, you are simply wrong. The Richmond FSDO tried that line and got
slapped down by FAA HQ with a memo that specifically says dual controls
do not mean dual brakes. Heck some planes have no brakes.
wskimike wrote:
Quote: | I don't think you understood about the CFI. If you plan to get a
includes brakes.
KCHD |
Kellym
Posted: Thu Aug 28, 2008 9:09 pm Post subject: dual brakes vs. single |
Nope, the rules weren't changed, just clarified with a General Counsel
memo (IIRC) to straighten out the knuckle draggers at Richmond FSDO.
Dual brakes are not required for flight checks, check rides, BFRs, etc.
IF the CFI feels a need for them for a particular student, then a
different aircraft should be used to satisfy the CFI's concern, but
there is NOTHING in the regs requiring dual brakes. Many certified
aircraft, such as Mooneys do not have dual brakes. I've gotten plenty of
instruction, BFRs and IPCs in Mooneys with only left side brakes,
regardless of whether I was flying left or right seat. Not to mention
all the old aircraft that only had tail skids and no brakes. No aircraft
on skiis or floats have any brakes..makes no difference for flight check
or instruction.
any attention to the rule, even in TW planes, if they know you & your
koolaid drinking nazi's, it might be worth some research.
> nosewheel aircraft.
> side.
> Tom Sargent, RV-6A.
KCHD |
Posted: Fri Aug 29, 2008 6:17 am Post subject: dual brakes vs. single |
Quote: | Seems like a lot of anguish over just a few pounds.
For some people, I agree it is not an issue weight wise one way or
the other. I on the other hand looked at every piece of equipment on
my RV and asked: 1. How much does it weigh? 2. Do I really need
that extra weight? 3. If so, is there a lighter alternative available.
I usually only fly with 8-10 gals of fuel. I can tell a big
difference between 10 gals and 38 gals in the performance of my
aircraft. And with a passenger, I can really tell the difference. I
like the feel and performance of my aircraft at the lightest possible
weight. And 2 pounds here and 2 pounds there really add up. And it
is not really 2 pounds it is 12 pounds at 6 Gs!
And the passenger brakes that I don't have, have never leaked, nor do
they require any maintenance for the entire life of the aircraft.
Posted: Fri Aug 29, 2008 6:33 am Post subject: dual brakes vs. single |
Thanks to everyone who has commented on this. I have decided to remove
the right side brakes and move my brake fluid reservoir over to the left
side of the firewall, mainly because of the simplification it offers.
1- easier routing of lines (my main issue now)
2- fewer joints to leak,
3- easier to bleed to brakes (since there's less tubing, I'm guessing)
The few pounds of weight saving is a extra bonus, though it's important too.
Tom S., RV-6A,
almost ready to rivet the forward top skin.
Posted: Sat Aug 30, 2008 3:35 pm Post subject: dual brakes vs. single |
FWIW: I removed the right side brake cylinders, pedals, nuts, bolts,
tubing etc., and weighed it all very carefully. The weight saving was 2
pounds exactly.
Tom S., RV-6A
