AirMike
Posted: Tue Sep 02, 2008 1:43 pm Post subject: Nav Antenna |
I am at the point of installing an "In-Wing" Nav antenna. I saw that Vans has such a Nav antenna on their web site (with no picture)- it was quite inexpensive. I ordered it and it is essentially a piece of 25" copper tape to which you solder a connection with the (included) antenna wire to the panel. Has anyone installed this device and with what level of success in receiving VOR signals. If it is ho-hum on the reception, should I try the Bob Archer unit that sells for about $88 at Spruce???
_________________ See you OSH '18
Q/B - sold. |
ron.mcgann(at)baesystems. Guest
Posted: Tue Sep 02, 2008 3:04 pm Post subject: Nav Antenna |
Hi Mike,
Sounds like you are describing the Marker Beacon Antenna. It won't be
much chop for VOR reception. If you are after a VOR antenna in the
wing, you will nee the Bob Archer Nav antenna (or equivalent).
Ron
187 painting
AirMike
Posted: Sat Sep 06, 2008 5:27 am Post subject: Re: Nav Antenna |
This is supposed to be a Nav antenna (25")
repeat request for any info on anyone who has installed one???
Q/B - sold. |
