JohnInReno
Posted: Fri Sep 05, 2008 9:50 am Post subject: ELT Mounting Bracket |
Why does the mount for the Ameri-King ELT have a "wedge" under the rearward end so that the radio is tilted 20 up in the back?
John Morgensen
RV-9A fuselage
Grumman AA1B-150
_________________ John Morgensen
RV-9A - Born on July 3, 2013
RV4 - for sale |
Bret Smith
Joined: 09 Jan 2006 Posts: 178 Location: Mineral Bluff, GA
Posted: Fri Sep 05, 2008 10:47 am Post subject: ELT Mounting Bracket |
It doesn't. Loosen the strap and slide the unit forward until it sits flat,
then re-fasten the strap.
Bret Smith
RV-9A N16BL
Blue Ridge, Ga
www.FlightInnovations.com
_________________ Bret Smith
RV-9A (Emp) |
JohnInReno
Posted: Fri Sep 05, 2008 11:33 am Post subject: Re: ELT Mounting Bracket |
I should have included pictures the first time. This is the Ameri-King 451 406 ELT and the very first ELT that I have ever dealt with. There is a lip around the tray that completely surrounds the radio. The only way to move it forward would be to have the radio sit on the forward lip. See the attached pictures.
| JohnInReno wrote: | Why does the mount for the Ameri-King ELT have a "wedge" under the rearward end so that the radio is tilted 20 up in the back?
John Morgensen
RV-9A fuselage
Grumman AA1B-150 |
61.63 KB |
308 Time(s) |
65.24 KB |
312 Time(s) |
71.07 KB |
308 Time(s) |
RV4 - for sale |
rjquillin
Posted: Fri Sep 05, 2008 2:32 pm Post subject: ELT Mounting Bracket |
At 10:50 9/5/2008, you wrote:
| Quote: | Why does the mount for the Ameri-King ELT have a "wedge" under the
Mount for a helo?
They're at an angle...
Ron Q.
Speedy11(at)aol.com Guest
Posted: Fri Sep 05, 2008 11:19 pm Post subject: ELT Mounting Bracket |
Did you ask Ameri-King?
Stan
| Quote: | >Why does the mount for the Ameri-King ELT have a "wedge" under the
| Quote: | rearward end so that the radio is tilted 20 up in the back?
Mount for a helo?
They're at an angle... |
Psssst...Have you heard the news? There's a new fashion blog, plus the latest fall trends and hair styles at StyleList.com.
kyrilian_av(at)yahoo.com Guest
Posted: Sat Sep 06, 2008 6:57 am Post subject: ELT Mounting Bracket |
It's likely the mounting angle has something to do with impact activation during a crash, where most of the energy will be in the longitudinal direction, but some will be vertical. In helicopters, this angle will be greater since they tend to impact at a steeper angle.
The g-switch is likely mounted axial with the box. I presume the instructions call for one end (the one opposite the 'bump') to be mounted forward. Is this the case?
- Kyrilian
--- On Sat, 9/6/08, Speedy11(at)aol.com <Speedy11(at)aol.com> wrote:
[quote]From: Speedy11(at)aol.com <Speedy11(at)aol.com>
Subject: Re: ELT Mounting Bracket
Date: Saturday, September 6, 2008, 3:17 AM
Stan
Mount for a helo?
JohnInReno
Posted: Sat Sep 06, 2008 7:45 am Post subject: Re: ELT Mounting Bracket |
Yes - there is an arrow labeled "Forward" opposite the bump and it matches a similar arrow on the radio that can only be installed one way. I will contact Ameri-King next week to confirm but your analysis seems correct.
| kyrilian_av(at)yahoo.com wrote: | It's likely the mounting angle has something to do with impact activation during a crash, where most of the energy will be in the longitudinal direction, but some will be vertical. In helicopters, this angle will be greater since they tend to impact at a steeper angle.
- Kyrilian
RV4 - for sale |
