Lenny Iszak
Posted: Sun Sep 07, 2008 10:55 am Post subject: Elevator pushrod safety wire size |
What size safety wire did you guys use for the F-1089 elevator pushrod?
I didn't see any size specified in the plans. I used .041 and it seems to be binding...
Should I use a thinner wire or just make a bigger loop at the rod end bearing?
Lenny,
#40803
Tim Olson
Posted: Sun Sep 07, 2008 4:01 pm Post subject: Elevator pushrod safety wire size |
You might want to just buy a bunch of .032...you'll probably use that
for a lot of maintenance items later anyway. .041 is pretty thick.
Lenny Iszak wrote:
Lenny,
#40803
http://forums.matronics.com/viewtopic.php?p 3074#203074
Lenny Iszak
Posted: Mon Sep 08, 2008 4:22 am Post subject: Re: Elevator pushrod safety wire size |
Thanks Tim!
Lenny
