Phil.Perry(at)netapp.com Guest
Posted: Fri Sep 05, 2008 6:51 pm Post subject: Elevator Counterbalance |
I've reached the point of trimming the counterbalance weights for the elevators.
Without having a chance to balance the elevators first, trimming these weights make me a bit nervous. It seems like there is the possibility that Vans estimates could allow for too much removal.
If I trim the weights as the plans describe, is there still more than enough lead remaining to balance the control surfaces later?
If so, what's the process for removing the lead from a counterbalance weight that's already in place? A drill?
Phil
Posted: Fri Sep 05, 2008 7:04 pm Post subject: Elevator Counterbalance |
Yup....drill out the amount needed to bring it into balance. Adding it in is a little tougher, but easily done casting some lead sheet to go under the attach bolts.
Rick S.
40185
Posted: Fri Sep 05, 2008 7:54 pm Post subject: Elevator Counterbalance |
Thanks Rick..
Even though the plans don't call for it, I'm assuming I should go ahead and torque them down now.
Phil
From: Rick Sked [mailto:ricksked(at)embarqmail.com]
Sent: Friday, September 05, 2008 10:04 PM
Subject: Re: Elevator Counterbalance
Rick S.
40185
carl.froehlich(at)cox.net Guest
Posted: Sat Sep 06, 2008 4:44 am Post subject: Elevator Counterbalance |
There is not enough lead, even before trimming, to balance the elevators like you would on a two place RV. I called Van’s about this and the response was for the RV-10 the elevators are supposed to be trailing edge heavy, and to trim and install the weights per plan.
Carl Froehlich
RV-8A (450 hours)
RV-10 (fuselage)
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Perry, Phil
Sent: Friday, September 05, 2008 11:53 PM
Subject: RE: Elevator Counterbalance
Thanks Rick..
Phil
Rick S.
40185
Posted: Sat Sep 06, 2008 7:26 am Post subject: Elevator Counterbalance |
I wouldn't. I hung mine initally to see how close they were...very close really, but you need to redo it after all the bodywork and paint is completed...so snug them up to keep them in place unti; your final balcane is completed, I use torq seal on everything so if I don't have the yellow seal I always recheck the torque, beats making a list as long as you stick to your method of never letting one go if it is not marked.
Rick Sked
40185
Dick Sipp
Posted: Sat Sep 06, 2008 6:40 pm Post subject: Elevator Counterbalance |
Gentlemen:
Let's remember that the 10 is the only RV that has a balance spec. It is found in the table in the text instructions (section 5 I think). They are not to be balanced "level" but with a maximum trailing edge down weight IIRC. There is a spec for each control surface. Naturally they should be checked after painting.
Dick Sipp
