cnpeters
Joined: 24 Aug 2006 Posts: 23 Location: Bloomington/Normal, IL
Posted: Sun Aug 17, 2008 8:23 pm Post subject: Lycoming IO-360 A1A used vs new question |
I translated and summarized the following for an RV-7A builder in Italy named Lucio. He acquired a used Lyc IO-360 A1A in parts (no history or other info given), and a trusted mechanic can rebuild it for 8K euros. He would like to know if this type of Lycoming is a trustworthy engine for the RV-7A in general, any historical problems with it, etc. Also he would like to know if it is worth rebuilding this engine vs. buying new from Van's. With devalued dollar, he can get a new engine cheap, BUT with high transportation and import taxation costs, it would add up to 22k euros (north of $30k).
OK, my take on this:
Can't tell much about whether the used engine is any good from his note. Crankshaft OK? History of damage/prop strike? TT and TT SMOH? Why is it in parts? Corrosion? Camshaft OK? Any AD's on the parts/crank that need complying with? Basically, I would advise to have the engine inspected by a knowledgeable mechanic first, before agreeing to a $12k rebuild. There are many stories of these used engines ending up costing far more than a new one when everything is done. Since this engine is in parts, it will be much cheaper to inspect than doing a teardown.
As to the IO-360 A1A engine and the RV-7A, it is a popular combo (more as in the carburetor configuration) and would be an excellent powerplant capable of meeting Van's published performance speeds at fuel burns near 8 gallons per hour lean of peak with the fuel injection. Any other thoughts from group?
Carl
| | - The Matronics RV7-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?RV7-List |
_________________ Carl Peters
RV-9A wings |
