Posted: Thu Mar 16, 2006 12:02 pm Post subject: OT Translation question |
Hi Bob and all,
A fellow builders in my area is having problems translating the
expression "runner-log-branch", in the following paragraph from G.Braly
on TC engine mixture problems.
> > <<This pattern is almost universal among big bore TCM engines with
> > the runner log-branch induction systems. The pattern is consistently
> > observed because it is a result of the inherent design of the runner
> > log-branch induction system. >>
I know what induction runners are, but I'm at loss accurately rendering
the expression.
Anyone care to put this into clearer words for us non naturally English
speakers ?
The following may be similar to the text my buddy is translating :
http://www.nar-associates.com/technical-flying/Vibration/Vibnet.pdf
Any input appreciated,
Thanks in advance
Gilles Thesee
Grenoble, France
http://contrails.free.fr
mprather(at)spro.net Guest
Posted: Thu Mar 16, 2006 12:51 pm Post subject: OT Translation question |
Gilles,
Most (all?) of the big bore Continentals (TCM) have the induction system
split into two halves - one for each side of the engine. Each half
essentially consists of a single large aluminum tube oriented to run near
the intake port on each cylinder. This is the 'log.' There's an opening
in the 'log' immediately under the each cylinder's port. Individual tubes
connect from each cylinder port to its respective opening on the 'log'.
These are the 'branches'. In reality, the 'runner-log-branch' is formed
in segments from aluminum T's. The center of each T connects to the
cylinder port. The sides of each T connects to the adjacent cylinder on
each side (or to a tube that goes to the carburetor or the crossover).
A picture is worth 1k words:
http://a1aero.com/files/DSCN0662.JPG
The 'log' is connected together by the orange hoses in the picture.
Matt-
<Gilles.Thesee(at)ac-grenoble.fr>
Hi Bob and all,
consistently observed because it is a result of the inherent design
of the runner log-branch induction system. >>
the expression.
speakers ?
Thanks in advance
Gilles Thesee
Grenoble, France
Kellym
Posted: Thu Mar 16, 2006 12:52 pm Post subject: OT Translation question |
The engines referred to have a cylindrical tube that runs parallel to
the crankshaft on the outside, below the cylinder heads,(on both sides
of the engine) that is the induction manifold. There is an individual
runner from that tube to each cylinder, and a runner at the front of
the engine connecting the two tubes. It sort of loosely looks like a
wooden log, with branches or runners coming from it.
That is what makes it different from the Lycoming type intakes where
you have a single plenum, usually as part of the oil sump, with
individual manifold tubes to each cylinder.
Quoting Gilles Thesee <Gilles.Thesee(at)ac-grenoble.fr>:
Hi Bob and all,
the expression.
speakers ?
Thanks in advance
Gilles Thesee
Grenoble, France
KCHD |
brian
Joined: 02 Jan 2006 Posts: 643 Location: Sacramento, California, USA
Posted: Thu Mar 16, 2006 1:08 pm Post subject: OT Translation question |
Gilles Thesee wrote:
Hi Bob and all,
the expression.
speakers ?
The "runner log" is somewhat like the trunk of a tree. It is larger in
diameter and straight. The actual induction tubes that go to each
cylinder "branch" off the "log" just like the branches of a tree. The
name is intended to convey a picture of a wood log with branches coming
off of it.
This is used to describe the older, non-tuned induction system used on
TCM engines. The problem is that not every cylinder receives the same
amount of air and fuel which results in differences in power output and
mixture at each cylinder.
Newer engines have a tuned induction system that does a better job of
getting air to each cylinder. Each cylinder receives (almost) the same
amount of air and the injection system ensures that each cylinder
receives the same amount of fuel. The whole idea behind GAMI's custom
injection nozzles is to match the fuel flow to the airflow at each
cylinder, thus ensuring that each cylinder receives *exactly* the same
fuel-air mixture. This then makes lean-of-peak operation possible.
Brian Lloyd
brian-yak(at)lloyd.com
_________________ Brian Lloyd
brian-yak at lloyd dot com
- Antoine de Saint-Exupery |
Posted: Thu Mar 16, 2006 2:36 pm Post subject: OT Translation question |
Matt, Kelly, Brian,
Thanks a lot for your explanations and picture.
Things are much clearer now. So it really was a wooden log...I was not
so far, after all
Thanks again,
Gilles Thesee
Grenoble, France
