etienne.phillips(at)gmail Guest
Posted: Tue Sep 09, 2008 11:36 pm Post subject: SD-8, voltage regulator and OV module |
Hi all
I would like to install a SD-8 into my currently alternatorless VFR aircraft, but I'm a bit confused... What voltage regulator do I need to use? I'm planning on using the 504-1 OV module, with the standard 5A circuit breaker.
I'd also prefer not to have another switch between the alternator and the main bus. If I need to disconnect the alternator from the bus, I'll pull the breaker, which will de-power the relay in the OV circuit.
Etienne
nuckolls.bob(at)cox.net Guest
Posted: Wed Sep 10, 2008 4:13 am Post subject: SD-8, voltage regulator and OV module |
At 09:32 AM 9/10/2008 +0200, you wrote:
| Quote: | Hi all
circuit breaker.
that will work
bob . . .
| Quote: | Hi all
circuit breaker.
The regulator comes with the SD-8
| Quote: | I'd also prefer not to have another switch between the alternator and the
that will work
bob . . .
Posted: Wed Sep 10, 2008 5:43 am Post subject: SD-8, voltage regulator and OV module |
Great!
One less thing to buy
Thanks Bob
2008/9/10 Robert L. Nuckolls, III <nuckolls.bob(at)cox.net (nuckolls.bob(at)cox.net)>
[quote]--> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckolls.bob(at)cox.net (nuckolls.bob(at)cox.net)>
| Quote: | Hi all
| Quote: | I'd also prefer not to have another switch between the alternator and the main bus. If I need to disconnect the alternator from the bus, I'll pull the breaker, which will de-power the relay in the OV circuit.
that will work
bob . . .
