Joe(at)hambrothers.com Guest
Posted: Wed Sep 10, 2008 10:27 am Post subject: sound proofing and or insulation |
the only thing i have seen on the above was in the june 07 issue of kit planes.
they used foam rubber. does any one have any sugestions .
johnd(at)data-tech.com Guest
Posted: Wed Sep 10, 2008 10:38 am Post subject: sound proofing and or insulation |
Hi Joe,
Aircraft Spruce carries a variety of insulating and soundproofing materials. In my 601 I used 'The Insulator' (http://www.aircraftspruce.com/catalog/appages/insulator.php) and it seems to work well.
John Davis
601 XL - Waiting for final inspection...
Burnsville, NC
Joe wrote: [quote] the only thing i have seen on the above was in the june 07 issue of kit planes.
href="http://www.matronics.com/Navigator?Zenith-List">http://www.matronics.com/Navigator?Zenith-List
| [b]
Gig Giacona
Posted: Wed Sep 10, 2008 11:08 am Post subject: Re: sound proofing and or insulation |
John, did you use the single foil sided or double sided?
| johnd(at)data-tech.com wrote: | Hi Joe,
John Davis
Burnsville, NC
601XL Under Construction
Posted: Wed Sep 10, 2008 11:18 am Post subject: sound proofing and or insulation |
Hi Gig,
I used the double sided material on the cabin side of the firewall.
John
Gig Giacona wrote: [quote] | Quote: | --> Zenith-List message posted by: "Gig Giacona" <wrgiacona(at)gmail.com> (wrgiacona(at)gmail.com)
W.R. "Gig" Giacona
[url=http://forums.matronics.com/viewtopic.php?p 3658#203658]http://forums.matronics.com/viewtopic.php?p 3658#203658[/url]
| [b]
Posted: Wed Sep 10, 2008 1:17 pm Post subject: sound proofing and or insulation |
Hi Joe,
I recently went thru the soundproofing process using the "fireproof
foam" from
Aircraft Spruce. Not a difficult job. My Journal Section 12 in October
covers
the experience rather well and the test that followed. I am very
satisfied having
done this, as it did quiet the plane considerably. Hit the link below
and spool down to
Oct 27 - 28 and you'll see a page or so of how I did it.
www.macsmachine.com/html/journal12.htm
Joe wrote:
| Quote: | the only thing i have seen on the above was in the june 07 issue of
kit planes.
daveaustin2(at)primus.ca Guest
Posted: Wed Sep 10, 2008 3:07 pm Post subject: sound proofing and or insulation |
IMOO, I'd use nothing that would burn, smolder, smoke or give off toxic gasses.
Dave Austin 601HDS - 912
ggower_99(at)yahoo.com Guest
