Phil.Perry(at)netapp.com Guest
Posted: Sun Apr 04, 2010 7:58 am Post subject: CI-122 Template |
Does anyone have the dimensions or a template for the Comant CI-122 doubler?
I'd like to go ahead and put the doubler on the belly and pull the coax while I have decent access.
Phil
wcurtis(at)nerv10.com Guest
Posted: Sun Apr 04, 2010 9:09 am Post subject: CI-122 Template |
A Google search of "Comant CI-122" returns this as the forth listing.
http://www.comant.com/Uploads/technicalsheets/pp_CI_122712.pdf
William
N40237 - http://wcurtis.nerv10.com/
On Sun, Apr 4, 2010 at 11:54 AM, Perry, Phil <Phil.Perry(at)netapp.com (Phil.Perry(at)netapp.com)> wrote:
Phil
tsts4
Posted: Sun Apr 04, 2010 10:32 am Post subject: Re: CI-122 Template |
Just food for thought, but I know some folks make their antenna doublers larger than just the antenna base plate and add flanges either by bending or riveting on angle. The purpose of the flange(s) is to be able to tie the doubler into some structure (ie a rib, frame, or stiffener) other than just the skin.
_________________ Todd Stovall
aka "Auburntsts" on EAA and VAF
RV-10 N728TT -- Flying |
Kelly McMullen
Posted: Sun Apr 04, 2010 11:54 am Post subject: CI-122 Template |
IIRC doublers are supposed to be at least 50% larger surface area than
the antenna they support.
On Sun, Apr 4, 2010 at 11:32 AM, tsts4 <tsts4(at)verizon.net> wrote:
Todd Stovall
728TT (reserved)
RV-10 Empacone, Wings
http://forums.matronics.com/viewtopic.php?p=292960#292960
A&P/IA, EAA Tech Counselor
KCHD |
