henrysfork1(at)msn.com Guest
Posted: Sat Sep 20, 2008 6:02 pm Post subject: Smooth 8.00X20.00" tire |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> I mentioned some time back that I had found a source for new new tundra tires for the Kitfox. What I did was go to the local tire store and order the proper size of ATV tires. Have the tire store send them to the retread shop and have them shaved. Don't tell them they will be used on an aircraft or your SOL. I received a new set this week and the tires seem to be made much better than those that came stock in my model II. Anyway this worked for me and it may for you too. Cost wasn't that bad either, about $80.00.
Dee Young
Model II
N345DY
Mnflyer
Posted: Sun Sep 21, 2008 8:34 am Post subject: Re: Smooth 8.00X20.00 |
Hi Dee, what did they charge you to shave the tires? I just installed the King Fox tires and personally I'd prefer to have the original ATV tires I have thought about going back to my original tires but they are so old and getting weather checked, that I 'm probably better off to stick with the new tires.
Just maybe I 'll check into doing what you did.
_________________ GB
MNFlyer
Flying a HKS Kitfox III |
shinco(at)bright.net Guest
Posted: Sun Sep 21, 2008 1:25 pm Post subject: Smooth 8.00X20.00" tire |
Dee Young wrote:
| Quote: | I mentioned some time back that I had found a source for new new
them to the retread shop and have them shaved. *_Don't tell them they
will be used on an aircraft or your SOL._* I received a new set this
Dee Young
Model II
N345DY
Checked by AVG - http://www.avg.com
Dee,,go to Tires Unlimted.com Dayton Ohio-Tires Unlimted why go
through all the trouble ..of getting them shaved etc.They have then in
stock,and if they do not,they will get them for you there..they have
tubes all so..they will ship then right to your home..I have bought a
pair from them..and they are all ready smooth.no tread..and the cost is
right..and they are cheaper too than the cost that you gave..the tires
are called NANCO TIRES. they are the same as the KING FOX Tunda Tires.
But hey dont trust me..go to there web site.or call them..and then tell
me I told you so...Steve Shinabery N554KF KF2 Home to the Great Lakes
Area KIT FOX Fly In,,,coming in July 2009 see you there
peteohms
Posted: Sun Sep 21, 2008 1:56 pm Post subject: Smooth 8.00X20.00" tire |
Steve,
What is the part number?
Pete KF III SN 1000 912
_________________ Pete
Leander, TX
Kitfox III, 912ul, Grove |
dwight purdy
Posted: Sun Sep 21, 2008 2:16 pm Post subject: Smooth 8.00X20.00" tire |
Steve
Itried there a few yeas ago and they were out and not expecting any till the
next large batch from asia made.
Dwight Purdy
Model II
_________________ dwight
model II |
Posted: Sun Sep 21, 2008 4:13 pm Post subject: Smooth 8.00X20.00" tire |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> No part number just 20X7x8 Carlisle makes them plus several other manuf.
Dee Young
Model II
N345DY
Do not archive.
Posted: Sun Sep 21, 2008 4:22 pm Post subject: Smooth 8.00X20.00" tire |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> It cost me $80.00 for the tires ready to mount but my son manages a store so he helped me out on the price. I got the 20X7X8 which is the original size as I recall. I looked at the King Fox tires but didn't care for the larger size tires.
Dee Young
N345DY
