JabiruEngine-List Digest: 2 Msgs - 09/22/08
chinggisron
PostPosted: Thu Sep 25, 2008 5:34 am    Post subject: JabiruEngine-List Digest: 2 Msgs - 09/22/08 Reply with quote
I've using Baldwin 33 which is a good oil filter and rates more highly than the Fram in testing my Light Plane Maintenance.
--- On Tue, 9/23/08, JabiruEngine-List Digest Server <jabiruengine-list(at)matronics.com> wrote:
From: JabiruEngine-List Digest Server <jabiruengine-list(at)matronics.com>
Subject: JabiruEngine-List Digest: 2 Msgs - 09/22/08
To: "JabiruEngine-List Digest List" <jabiruengine-list-digest(at)matronics.com>
Date: Tuesday, September 23, 2008, 9:57 AM
Today's complete JabiruEngine-List Digest can also be found in either of
the
of the JabiruEngine-List Digest and can be viewed with a generic text editor
HTML Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 08-09-22&Archive=JabiruEngine
Text Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 08-09-22&Archive=JabiruEngine
JabiruEngine-List Digest Archive
Total Messages Posted Mon 09/22/08: 2
Today's Message Index:
1. 10:10 AM - 3300 First Oil Change (oil filter question) (DaveG601XL)
2. 10:21 AM - Re: 3300 First Oil Change (oil filter question) (Richard
Girard)
________________________________ Message 1
_____________________________________
Time: 10:10:11 AM PST US
Subject: 3300 First Oil Change (oil filter question)
I recently completed my first oil change at 25 hours. Without the Ryco filters
available from any local auto parts stores, I picked the equivalent Fram
filter.
At the same time, I was reviewing some past JabaChat newsletters and they
warned that some equivalent oil filters were causing oil pressure fluctuation
problems. The article did not mention any brand names. I sent an e-mail to
Pete at Jabiru USA asking about this but never heard back.
Has anybody had any problems with other commonly available auto oil filter
brands?
I want to know if there are any brands to shy away from.
My post-change oil pressure with the Fram is stable, but did note that it is
6-7
PSI higher than it was before the oil change. This is going from Aeroshell
100 mineral grade to Aeroshell W100.
I had my oil filter debris analyzed by my lab at work. It was primarily small
carbon deposits, some small aluminum pieces, carbon steel fuzz and just a few
bits of very small brass-like material. Overall, it was probably just what is
expected.
Flying is going very well so far and I am up to 30 hours on my 601XL/3300
combination.
I also recently installed a flow divider in front of the carb inlet and
got a marvelous climb-out power boost. I will present more data on this later
after I complete a few more test flights on the cruise effects of this mod.
Let's go flying!
David Gallagher
601 XL, first flight 7/24/08.
In Phase I flight test.
http://forums.matronics.com/viewtopic.php?p 5523#205523
________________________________ Message 2
Time: 10:21:00 AM PST US
Subject: Re: 3300 First Oil Change (oil filter question)
Dave, try this:
http://knizefamily.net/minimopar/oilfilters/index.html
Rick
On Mon, Sep 22, 2008 at 12:09 PM, DaveG601XL
filters available from any local auto parts stores, I picked the
equivalent
Fram filter. At the same time, I was reviewing some past JabaChat
newsletters and they warned that some equivalent oil filters were causing
oil pressure fluctuation problems. The article did not mention any brand
names. I sent an e-mail to Pete at Jabiru USA asking about this but never
heard back.
brands? I want to know if there are any brands to shy away from.
is 6-7 PSI higher than it was before the oil change. This is going from
Aeroshell 100 mineral grade to Aeroshell W100.
small carbon deposits, some small aluminum pieces, carbon steel fuzz and
just a few bits of very small brass-like material. Overall, it was
probably
just what is expected.
combination. I also recently installed a flow divider in front of the
carb
inlet and got a marvelous climb-out power boost. I will present more data
on this later after I complete a few more test flights on the cruise
effects
of this mod.
Let's go flying!
David Gallagher
Ron Deutch, N450PR
Lynn Matteson
PostPosted: Thu Sep 25, 2008 7:53 am    Post subject: JabiruEngine-List Digest: 2 Msgs - 09/22/08 Reply with quote
Same here....Baldwin B33, as suggested by Andy Sylvester about a year
ago.
Lynn Matteson
Kitfox IV Speedster
Jabiru 2200, 562 hrs...engine assembled and back in the plane; 3 test
flights today...more to come after some work is done.
Lynn
Kitfox IV-Jabiru 2200
N369LM
