Source for welding cable?
Sam
PostPosted: Tue Sep 23, 2008 9:11 am    Post subject: Source for welding cable? Reply with quote
I'm looking for a place to get some good 4AWG welding cable. (Small amounts- of course). I see McMaster-Carr has some, but I would prefer to get both black and red. Does anyone have any sources? I see some on Ebay also.
Sam Hoskins
Murphysboro, IL
www.samhoskins.blogspot.com
Sam Hoskins
aslsa.rng(at)gmail.com
PostPosted: Tue Sep 23, 2008 9:28 am    Post subject: Source for welding cable? Reply with quote
What about your local Tractor Supply, Orscheln's, Atwoods, fill in your local farm supply store. Welding supply outlets, too. If you can't get the red and black, Harbor Freight has those colors of shrink tubing for cheap.
Rick
On Tue, Sep 23, 2008 at 12:09 PM, Sam Hoskins <sam.hoskins(at)gmail.com (sam.hoskins(at)gmail.com)> wrote:
Sam Hoskins
Murphysboro, IL
[/b]
Sam
PostPosted: Tue Sep 23, 2008 9:39 am    Post subject: Source for welding cable? Reply with quote
Like anything else, there must be good and bad quality cable available out there. What would be the difference to look for?
Sam
On Tue, Sep 23, 2008 at 12:25 PM, Richard Girard <aslsa.rng(at)gmail.com (aslsa.rng(at)gmail.com)> wrote:
[quote]What about your local Tractor Supply, Orscheln's, Atwoods, fill in your local farm supply store. Welding supply outlets, too. If you can't get the red and black, Harbor Freight has those colors of shrink tubing for cheap.
Rick
Sam Hoskins
Murphysboro, IL
Sam Hoskins
nuckolls.bob(at)cox.net
PostPosted: Tue Sep 23, 2008 9:46 am    Post subject: Source for welding cable? Reply with quote
also.
If not seen it in colors in my local suppliers inventory.
The stuff I get here in Wichita is from a local welding
supply store that supplies my CO2 for the environmental
chamber.
See:
http://aeroelectric.com/Pictures/Wire/4AWG_Welding_Cable_1.jpg
This stuff is designed primarily for rough service . . .
lay out on gravel roads and be run over by dump-trucks.
Local pricing for cut lengths is about $1.25/foot
( -Thomas Paine 1776- )
blackoaks(at)gmail.com
PostPosted: Tue Sep 23, 2008 9:49 am    Post subject: Source for welding cable? Reply with quote
Hi Sam, I got mine from Wiremasters. Sedveral of us have used them, Deb was very helpful and the price for all their wire was the best I found.
Deb Sullivan
Account Executive
WireMasters, Inc.
Phone: 800-635-5342
Fax: 615-791-6182
Email: dsullivan(at) wiremasters.net (dsullivan(at)wiremasters.net)
Web site: http://www.wiremasters.net/ (dsullivan(at)wiremasters.net)
John McMahon
Lancair Super ES, S/N 170, N9637M (Reserved)
mrspudandcompany(at)veriz
PostPosted: Tue Sep 23, 2008 10:33 am    Post subject: Source for welding cable? Reply with quote
Sam
[quote]I would recommend the VU-TRON cable. It has fine strands and is very flexible. Your application may or may not need the flexibility. It is also very durable. I was only able to find it in orange, but will use shrink sleeving to identify. It is a little more expensive but for me, worth the extra cost. My $.10 worth (inflation, you know) Roger [b]
wooody04(at)bellsouth.net
PostPosted: Tue Sep 23, 2008 12:53 pm    Post subject: Source for welding cable? Reply with quote
Sam, B&C has it in both red & black and will cut whatever length you need
Jim Streit
90073
Sam Hoskins wrote: [quote] I'm looking for a place to get some good 4AWG welding cable. (Small amounts- of course). I see McMaster-Carr has some, but I would prefer to get both black and red. Does anyone have any sources? I see some on Ebay also.
Sam Hoskins
Murphysboro, IL
Checked by AVG - http://www.avg.com
ronr(at)advanceddesign.co
PostPosted: Wed Sep 24, 2008 5:41 am    Post subject: Source for welding cable? Reply with quote
I have a surplus roll of # 2 welding cable aprox 120 feet left. Back in 2000 I paid 90 cents per foot. I also have the lugs 2.50 ea and the right crimper to put them on. I will make the cable with the lugs installed for the cost of the material. I also can put on a piece of red heat shrink if you want.
Ron Raby
www.advanceddesign.com
rv8iator
PostPosted: Wed Sep 24, 2008 6:23 am    Post subject: Source for welding cable? Reply with quote
Sam...
Check Waytek
http://order.waytekwire.com/CGI-BIN/LANSAWEB?WEBEVENT+L0F99F83E3041F200097A061+M37+ENG
Chris Stone
RV-8
Newberg, OR
C. Stone (RV8iator)
PostPosted: Wed Sep 24, 2008 10:06 am    Post subject: Source for welding cable? Reply with quote
I also have some extraflex 4awg tin coated fine stranded copper wire. The marking on the wire say's awm I A/B 105C FT1 LL59358. not sure what that means. seems better than welding cable. I paid 1.88 a foot. I have both black and green. I will sell it for a buck a foot.
Ron Raby
rampil
PostPosted: Wed Sep 24, 2008 11:54 am    Post subject: Re: Source for welding cable? Reply with quote
for the few feet you probably need, it doesn't make sense to mail order it.
any local welding supply will have appropriate cable. Welding cable
by definition is fine stranded 100% copper. Buy a touch long since
despite the fine stranding, it still has a significant bend radius
Ira N224XS
