batt.cable
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Tailwind-List
GPTAILWIND(at)msn.com
PostPosted: Sun Sep 28, 2008 6:19 am    Post subject: batt.cable Reply with quote
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Jim C. What are you using for Battery cable? Also what kind of a bulkhead fitting for the cables? Gordon
- The Matronics Tailwind-List Email Forum -
http://www.matronics.com/Navigator?Tailwind-List
jclement000(at)centurytel
PostPosted: Sun Sep 28, 2008 3:06 pm    Post subject: batt.cable Reply with quote
Gordon
I use #2 welding cable, single piece from master solenoid to starter
solenoid. I use a rubber grommet thru the firewall but on the backside a
3/16" thick piece of birch plywood. The plywood has a hole the same size as
the od of the cable, this is also fastened to the firewall. This will keep
the cable centered in the grommet and lessen the chance of the firewall
cutting into the cable.
Jim C
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Tailwind-List All times are GMT - 8 Hours
