smlplanet(at)msn.com Guest
Posted: Sat Sep 27, 2008 6:16 am Post subject: VG update |
After reading the numbers on the different VG installations I decided it give them a try. Mark III/912...594 lbs empty...no flaps installed.
10 gas in main fuel tanks and 3 gals in reserve nose tank for test flights. total of 13 gals.
W/O VG's 175 lbs pilot stall 44 asi ....W VG'S 36 asi power on
W/O VG'S 375 lbs duel stall 50 asi.... W VG'S 40 asi power on
31 VG'S total installed on wings 10 back from leading edge and set between every other rib plus 3 on the wing gap seal
It also increased the rate of climb 200 to 400 fpm. Ground roll smoother and shorter and landings much better and just wants to float in ground affect, very soft landings. There maybe a 1-2 mph lose on cruise and all testing was done in calm air
Worth the $35 including shipping off e-bay
Sent: 2008-08-11 10:31
To: Kolb list (kolb-list(at)matronics.com)
Subject: VG update
Since everyon is posting #'s
1.1 hrs legal instruction MKIII xtra 912ul 590lbs empty
132 vg's on wing tip to tip including gap seal
Parallel on vertical stab 2" apart
200lb pilot, calm air, 75 deg.
Power off stall 37 ias 35 flaps
39 ias power on
100 ias WOT (5600 rpm) 400lbs of pilot and passenger, full fuel(10 gals)
Stall with 2, 45 ias power off
No more yank to left with power eased up on takeoff.
Pre vg's needed a little right rudder in level flight.
Now, slight to no left rudder needed. I'm just guessing but vgs must be helping
trim tab work.
Landed 60 mph over the fence, forgot to look at touchdown.
It was so smooth that if the tires hadn't chirped you would'nt know you had landed.
So Ellery you don't have to dive at the runway.
Especially with a mile of asphalt, not to be confused with ass fault, thats just a crack.
Tickled in Maine
Vic
N740VP
JetPilot
Posted: Mon Sep 29, 2008 8:26 am Post subject: Re: VG update |
Thats great to hear Vic !!! This is exactly the reason that I went to the trouble of making the VG videos and posting the information on this list, I am happy I could contribute and help out some fellow Kolb flyers. There have been a number of other people that have also installed VG's on their Kolbs with positive results, but they have chosen to email me in private to thank me. Its a shame that some people have created such a hostile environment here that people are afraid to post information about their Kolbs on this list, but I respect their wishes.
35 dollars is a great deal for VG's, I am wondering if they are about the same size and shape as the ones I have used ? What are they made out of ? I paid 100 dollars for 100 VG, but still the best 100 bucks I have spent on the Kolb Can you post a link to where you got the VG's on ebay ?
Mike
Kolb MK-III Xtra, 912-S |
