VDC Battery Minders
bicyclop(at)pacbell.net
PostPosted: Tue Sep 30, 2008 1:51 pm    Post subject: VDC Battery Minders Reply with quote
Howdy,
Just got off the phone with the tech rep at VDC. Had a chat about the
difference between the "aviation adjusted" charger and the straight
12248. He says that the aviation specific batteries, ie; Concorde and
Gill, use a chemistry with a higher concentration of acid than other
batteries and require a different charge profile. He said that the
voltage is slightly lower and the time in the second phase of the charge
cycle is longer, and the voltage in the float is lower. The de-sulfation
circuit is exactly the same in all the models.
They also make a model of this charger specific to the Hawker Odyssey
battery which wants a higher charge voltage and specific charging
profile because of the pure lead used for the plates. They also have a
model for the Optima battery with it's own charging profile. He said
that these are all settable inside the unit via dip switch setting, but
not user accessible. I bet you'd void the warranty if you played around
with it.
He stated that leaving any battery hooked up to the wrong profile
charger for an extended period of time, say more than 3 months, would
damage it. That being said, he agreed that almost any sort of smart
charger would work for the occasional recharge of a battery kept
reasonably charged by it's vehicle or after a discharge capacity test.
If a battery were to be left hooked up the the straight 12248 charger
for a longer term float, one could mitigate the potential damage by
setting to the "Gell cell" setting which floats at a lower voltage and
wouldn't cook the battery off.
I told him that I didn't want to have to buy 3 or 4 chargers do do all
this. The key is that I fly often, nearly daily in fact. Most of the
people, to whom they sell chargers, don't and want something to keep
their batteries in tip-top shape even if they can't afford the avgas to
keep them charged up. He agreed with me, that for my purposes and taking
into account how I use a charger, that the 12248 would be the most
versatile of their offerings. The chargers sense ambient temperature and
so the $20 temp probe is of limited value is what we agreed. Your
mileage may vary.
By the way, the 12248 is on sale now at Northern Tool for $85, $15 less
than their regular price and a bunch cheaper than anywhere else I could
find. They, and VDC for that matter, have been out of stock, but the guy
said that Northern should be getting theirs in within a week.
Pax,
Ed Holyoke
ed(at)muellerartcover.com
PostPosted: Tue Sep 30, 2008 3:52 pm    Post subject: VDC Battery Minders Reply with quote
I think I've voided more warranties then I can remember.
I wonder if a nice 4 position switch would give it a lot of versatility.
Ed
On Sep 30, 2008, at 5:45 PM, Ed Holyoke wrote:
<bicyclop(at)pacbell.net>
Howdy,
charge cycle is longer, and the voltage in the float is lower. The
de-sulfation circuit is exactly the same in all the models.
but not user accessible. I bet you'd void the warranty if you played
around with it.
to keep them charged up. He agreed with me, that for my purposes and
taking into account how I use a charger, that the 12248 would be the
most versatile of their offerings. The chargers sense ambient
temperature and so the $20 temp probe is of limited value is what we
agreed. Your mileage may vary.
less than their regular price and a bunch cheaper than anywhere else I
could find. They, and VDC for that matter, have been out of stock, but
the guy said that Northern should be getting theirs in within a week.
Pax,
Ed Holyoke
nuckolls.bob(at)cox.net
PostPosted: Tue Sep 30, 2008 5:53 pm    Post subject: VDC Battery Minders Reply with quote
At 02:45 PM 9/30/2008 -0700, you wrote:
Howdy,
difference between the "aviation adjusted" charger and the straight 12248.
He says that the aviation specific batteries, ie; Concorde and Gill, use a
chemistry with a higher concentration of acid than other batteries and
require a different charge profile. He said that the voltage is slightly
lower and the time in the second phase of the charge cycle is longer, and
the voltage in the float is lower. The de-sulfation circuit is exactly the
battery which wants a higher charge voltage and specific charging profile
because of the pure lead used for the plates. They also have a model for
the Optima battery with it's own charging profile. He said that these are
all settable inside the unit via dip switch setting, but not user
accessible. I bet you'd void the warranty if you played around with it.
He stated that leaving any battery hooked up to the wrong profile charger
for an extended period of time, say more than 3 months, would damage it.
That being said, he agreed that almost any sort of smart charger would
work for the occasional recharge of a battery kept reasonably charged by
it's vehicle or after a discharge capacity test. If a battery were to be
left hooked up the the straight 12248 charger for a longer term float, one
could mitigate the potential damage by setting to the "Gell cell" setting
which floats at a lower voltage and wouldn't cook the battery off.
people, to whom they sell chargers, don't and want something to keep their
batteries in tip-top shape even if they can't afford the avgas to keep
them charged up. He agreed with me, that for my purposes and taking into
account how I use a charger, that the 12248 would be the most versatile of
their offerings. The chargers sense ambient temperature and so the $20
temp probe is of limited value is what we agreed. Your mileage may vary.
The only reason to put any kind of charger on an
RG battery is because you ran it down accidently
and you want to get it back to 80% or more capacity
before you fly again.
The self discharge rate on an RG battery is so low
that you should be able to put your airplane away
in the fall and come back next spring to crank it right
up.
If one insists on plugging the battery in for storage
every night and the battery was put away charged, the
charger won't even have a chance to do a full blown
recharge, top-off-drop-to-float cycle. This
slicing and dicing of float voltage from a charger
is mostly smoke and mirrors. Open circuit on a SVLA
battery at room temperature is right at 13.0 volts.
Ideal float voltage would be right at 13.0 volts too.
All you're wanting to do is externally offset the
internal leakage of the battery. Now if you really
screw up and float it at say 13.4 volts, the current
that flows into the battery will be somewhere around
30 mA on a 17 a.h. battery.
If you plan on routinely abusing the battery with
the "wrong charger" then perhaps there is value in
fine tuning the product. Keep in mind that your
airplane's electrical system really sucks for
air as a charging system. The alternator runs full-out
at recharge at top-off voltage until the recharge current
"breaks". Top-off voltage is maintained until engine
shut down. Typical recharge current after 2 hours of
flight will be on the order of 100 to 500 mA. No pampering
of the battery with a "float voltage" while in flight!
If I were chartered with crafting a new regulator
design, it would be software driven and have
some smarts that drops to a float voltage after
recharge is assured . . . increase in service life?
No idea. Won't launch into a $100K$ test program to
prove it one way or another.
I'll suggest that spending the $time$ to optimize
the recharging/maintaining of batteries in airplanes
is a lousy return on investment. If your battery
fails to meet manufacturer's fondest wishes
for a laboratory-pure service life, it's because
you have it bolted to an airplane . . . not because
you've charged it with the wrong charger.
Batteries used for motive power (golf carts, trolling,
weed eaters, etc) are another matter. These spend 99%
of their time on a charger getting replenished from
a deep-cycle service. You MIGHT see a couple more passes
around the yard or one more trip out onto the pond
by fine tuning the technology in the charger.
If you have a dead battery, charge it with ANYTHING
and go fly. If you're storing a battery for less than
60 days, don't beat it up with an unnecessary, less-than-
ideal charger. If you're storing over the winter,
take the battery home and put it on a Battery Tender
out in the garage until spring.
