Slick mag update SB2-08A and SB3-08A
Tim Olson
PostPosted: Thu Sep 18, 2008 4:32 am    Post subject: Slick mag update SB2-08A and SB3-08A Reply with quote
Unison Revises Slick Magneto Service Bulletin; Kits Available
Unison Industries has revised service bulletins on its Slick magnetos
and is currently shipping kits to enable compliance with the revised
SBs. Service bulletins SB2-08A and SB3-08A are revisions of earlier
bulletins. For affected Slick- and LASAR-brand magnetos (serial numbers
from 0610XXXX to 0804XXXX), installing the kits will constitute a
terminating action for the SBs. Others that might be affected are
magnetos that have had their cam (or the cam as part of the contact
point assembly kit) replaced with products shipped between October 1,
2006, and May 11, 2008. Unison is recommending replacing the entire
contact point assembly and distributor block and gear assemblies.
Service Bulletin SB3-08A affects magnetos with serial numbers from
0409XXXX to 08080453, and/or magnetos that have had the carbon brush or
distributor block replaced with products shipped between September 1,
2004, and August 14, 2008. For a limited time, the company is making the
kits available at reduced prices. Any Slick or LASAR magnetos
manufactured after August 15, 2008, are not affected by the SBs. For
more information, go to http://www.unisonindustries.com/
https://unisonpubs.com/docs/F-1100-SB3-08A.pdf
MauleDriver(at)nc.rr.com
PostPosted: Mon Sep 29, 2008 10:33 am    Post subject: Slick mag update SB2-08A and SB3-08A Reply with quote
I'm subject to the bulletin and I want to get the kit. I've been trying
to reach Unison on the phone but get no answer or call back. I've
searched the site and come up empty handed.
I have a Lycoming YIO-540.
Can anyone point me to a contact or URL where I can go about getting the
kit?
Thanks.
numbers from 0610XXXX to 0804XXXX), installing the kits will
constitute a terminating action for the SBs. Others that might be
affected are magnetos that have had their cam (or the cam as part of
the contact point assembly kit) replaced with products shipped between
October 1, 2006, and May 11, 2008. Unison is recommending replacing
the entire contact point assembly and distributor block and gear
assemblies. Service Bulletin SB3-08A affects magnetos with serial
numbers from 0409XXXX to 08080453, and/or magnetos that have had the
carbon brush or distributor block replaced with products shipped
between September 1, 2004, and August 14, 2008. For a limited time,
the company is making the kits available at reduced prices. Any Slick
or LASAR magnetos manufactured after August 15, 2008, are not affected
by the SBs. For more information, go to http://www.unisonindustries.com/
Rhonda(at)bpaengines.com
PostPosted: Mon Sep 29, 2008 11:46 am    Post subject: Slick mag update SB2-08A and SB3-08A Reply with quote
My understanding is that the kits are on back order due to
"overwhelming" response. Go figure. Another option would be to purchase
the brushes and cams through a shop like Quality Aircraft Accessories
(918) 835-6948. Quality will also do the labor for $75/mag, if new/low
time. If more than 100 hours, I think they are charging a little bit
more.
Best,
Rhonda
chuck(at)chuckdirect.com
PostPosted: Tue Sep 30, 2008 7:36 am    Post subject: Slick mag update SB2-08A and SB3-08A Reply with quote
Purchased brand new Slicks about three months ago from Spruce. Installed
them on the engine but not run yet. What would you do, send them back for
refund then repurchase? What?
Chuck
PostPosted: Thu Oct 02, 2008 1:49 pm    Post subject: Slick mag update SB2-08A and SB3-08A Reply with quote
Unfortunately, I have been told that Unison (now owned by Champion -
well the mags/harness lines anyway) will not honor a warranty/return on
new mags unless the cam/brushes are found to have wear at the inspection
intervals outlined in the SB. I also don't believe they will cover any
labor. If it were me I wouldn't wait, especially with Champion picking
up the product lines. I think the delay on the repair kit may end up
being significant.
Rhonda
