Deems Davis
Posted: Fri Oct 03, 2008 7:24 am Post subject: Elevator balance |
OK, after 2 1/2 months 'vacation' while the plane was at the painter,
the parts are back from the painter, and in reviewing the archive I see
reference to Van's spec of 37.5 in /lbs to balance the elevators, but
I'm not sure what exactly how to go about measuring / verifying them.
What procedure/process/technique have people used?
I also saw a reference, from Van's the 'just build them to plan and that
they naturally hang low. ???????
Deems Davis # 406
'Its all done....Its just not put together'
http://deemsrv10.com/
Kellym
Posted: Fri Oct 03, 2008 7:55 am Post subject: Elevator balance |
Deems
You need a couple knife edges to put the hinge bolts on, an accurate
balance, preferably digital for ease of use, to measure the downforce on
the rear edge of elevator.
Perhaps you can persuade some Copperstate attendees to give you a hand.
It is an operation where 4 hands or more are helpful. I would NOT skip
the balancing, given all the speed mods and hp mods I think you have,
which will have you pushing the upper end of Vne.
Deems Davis wrote:
see reference to Van's spec of 37.5 in /lbs to balance the elevators,
but I'm not sure what exactly how to go about measuring / verifying them.
that they naturally hang low. ???????
Deems Davis # 406
KCHD |
