Rudder Tip Rib
ifly4fun2(at)sbcglobal.ne
PostPosted: Wed Oct 01, 2008 6:37 pm    Post subject: Rudder Tip Rib Reply with quote
Hey List,
I've completed hand forming the 7R1-1 rudder tip rib, well few of them but I think the latest came out exceptionally well. No real concern of mine but the amount of flange material at the tip was SWAG'd as the plans are not very clear in where to taper off the material from the nose, what do you all think? Only looking for opinions here, ultimately I know the decision resides as my own.
Thanks in advance,
Art Olechowski
701 Rudder/750 Plans on Order
 Filesize:  1.06 MB
 Viewed:  427 Time(s)
kmccune
PostPosted: Wed Oct 01, 2008 7:18 pm    Post subject: Re: Rudder Tip Rib Reply with quote
Looks pretty good, the plans are not clear on a number of things like this, while being crystal clear on other things of the same type. Careful of making sharp radii, cracks and the dents made by the fluting pliers. I had way more trouble with the stab tips then the rudder tip and it was due to exactly what you are saying.
Good Luck and remember this is pretty cheap fun building an airplane from scratch, so don't worry about a few remakes!
Kevin
R.W. Emerson (1803-1882)
Dorothy McCune
PostPosted: Thu Oct 02, 2008 8:03 pm    Post subject: Rudder Tip Rib Reply with quote
Thanks for response Kevin, the remakes are anticipated (and cheap) as well as the fun. The fluting pliers were borrowed. I used them to get the material trained then I used the slots in the form block for the remainder. Need to weld up my own as the needle nose type. Thanks for the feedback and vote of confidence, looking forward to the challenge of the stab tips...for now.
Art
--- On Wed, 10/1/08, kmccune <kmccune(at)somtel.net> wrote:
[quote]From: kmccune <kmccune(at)somtel.net>
Subject: Re: Rudder Tip Rib
To: zenith701801-list(at)matronics.com
Date: Wednesday, October 1, 2008, 10:18 PM
[quote]--> Zenith701801-List message posted by: "kmccune"
you are saying.
Kevin
Mark Twain: Twenty years from now you will be more disappointed by the things
that you didn't do than by the ones you did do. So throw off the bowlines.
Sail away from the safe harbor. Catch the trade winds in your sails. Explore.
Dream. Discover.
Read this topic online [quote][b]
kmccune
PostPosted: Fri Oct 03, 2008 5:06 am    Post subject: Re: Rudder Tip Rib Reply with quote
Don't let me discourage you, as you may well be better then me at it. Besides we all ruin parts, its just that scratch builders can replace them Cool
Kevin
Dorothy McCune
