815TL
Posted: Fri Oct 10, 2008 3:19 pm Post subject: 582 starter not engaging. |
Hi all,
I went start up the plane tonight, my instructor was going to take it up for a flight, and could not get it to start. The volts show good, but is sounds like the starter is not engaging fully. I turn the key, and the starter clunks, moves the prop about an inch, then disengages and spins.
Can anyone lead me in the right direction as to what to look for? Could it be something as simple as lubrication? How and with what should I lubricate it with? Any other ideas?
I am still new to the Rotax/Kitfox world, so any information anyone could give, would be appreciated.
Andrew
Fox5flyer Guest
Posted: Fri Oct 10, 2008 4:42 pm Post subject: 582 starter not engaging. |
Lubrication is doubtful. With the cowling off, get under the airplane and
with a flashlight and see if you can see any part of the flywheel. Have a
good look at it while someone turns the prop slowly. You may be able to
see what is happening from that angle. Sounds like something is jamming.
Deke Morisse
Mikado Michigan
S5/Subaru/CAP 397+ TT
"The aim of an argument or discussion should not be victory, but progress."
- Joseph Joubert
shinco(at)bright.net Guest
Posted: Sat Oct 11, 2008 1:56 am Post subject: 582 starter not engaging. |
815TL wrote:
Hi all,
Andrew
http://forums.matronics.com/viewtopic.php?p 8232#208232
Checked by AVG - http://www.avg.com
I am going through the same thing right now..mine does not do any
thing..only clicks...BAD starter..engine will have to be pulled to
replace.can turn starter by hand and then engine will start .then have
to turn starter again..and so on..Bad starter.wish you luck...I am going
out and pull my Dam_ engine....Steve Shinabery N554KF KF2 St.Marys Ohio
815TL
Posted: Sat Oct 11, 2008 4:51 am Post subject: Re: 582 starter not engaging. |
Thanks guys. I will get a chance tomorrow to check it out. It clicks then spins, so I think it is OK, something is just not meshing. I guess I will need to check it out.
Andrew
Guy Buchanan
Posted: Sat Oct 11, 2008 5:25 am Post subject: 582 starter not engaging. |
At 05:41 PM 10/10/2008, you wrote:
| Quote: | With the cowling off, get under the airplane and with a flashlight
and see if you can see any part of the flywheel. Have a good look
at it while someone turns the prop slowly. You may be able to see
Andrew,
Deke's got good advice as there is an SL or SB on the 582
flywheel, which can fail. You should be able to check it without
pulling the engine. You can also see the starter in action from the
front if you pull the cowl. Watch it while someone hits the starter.
(Don't get your head cut off, though!)
Guy Buchanan
San Diego, CA
Deceased K-IV 1200
A glider pilot too. |
malpass
Joined: 27 Aug 2007 Posts: 39 Location: Marietta, Georgia
Posted: Sat Oct 11, 2008 5:47 am Post subject: 582 starter not engaging. |
Just so happens that I am repairing my starter as we speak as I had the same
identical symptoms. I had some very helpful Kitfoxer's explain to me what
is probably happening, and they turned out to be right on the money. This
applies only to the rear mounted starter on the 582.
Take a look at the pilots side stud holding the starter on. This is the one
that always breaks into. The starter will "rock" slightly to the righ and
left seeming loose. Its enough to not allow the starter to engage all the
way.
If this is you issue, dont try to get at the starter from the cabin side,
it is futile..............Got to take the engine out to repair. (good time
to go ahead and do a decarb job on the pistons).
Good luck, and you better hope this is all it is, because this is better
than a problem with flywheel, bad starter , etc.
Bill
_________________ kitfox III w/ 582 greyhead |
815TL
Posted: Sat Oct 11, 2008 7:17 am Post subject: Re: 582 starter not engaging. |
Man, I really hope I don't have to pull the motor on it right now. I wanted to get some flying time in. Is there any way to reach that bolt, without pulling it?
Andrew
Fox5flyer Guest
Posted: Sat Oct 11, 2008 7:39 am Post subject: 582 starter not engaging. |
Andrew, don't let pulling the engine slow you down. It's only about a 20
minute job with an overhead hoist or if you have big muskles, you can just
lift it out of there. Once you get it out it should be evident what the
problem is.
Deke Morisse
Mikado Michigan
- Joseph Joubert
malpass
Posted: Sat Oct 11, 2008 7:59 am Post subject: 582 starter not engaging. |
There are some 10 rubber washers per side and the stud to replace , so I
dont think a surgeon could even pull something off like a repair such as
this. Your going to have to get the engine out. Just visually check and
you can make sure the broken stud is the problem first.
Make sure this is the problem...........................
Bill
815TL
Posted: Sun Oct 12, 2008 4:42 am Post subject: Re: 582 starter not engaging. |
Good morning all.
Well, I have some good news after looking the situation over. I tried another battery, but it still would not engage. So we tore the cowling off to see what it was doing. I had someone crank it over, while I looked at it from underneath. The mounting bolts were fine, so I new that was not the problem. I looked to me, and forgive me if I use the wrong terms here, like the gear would spin forward and latch on to the flywheel, but the pack (pressure plate?) would not slide forward.
There was a lot of old thick lubrication on it. I cleaned it a little, then sprayed it good with some thin lubricant.
Out of 20 tries after that, it failed to engage just 2 times. So it now seems to engage 9 out of 10 times. That is a lot better than 0 out of 10 times. I will keep an eye on it, but I think that was the whole issue.
Thank you all for all your help and information.
Andrew
