zackrv8(at)verizon.net Guest
Posted: Sat Jan 07, 2006 6:58 pm Post subject: RV10 Trim Tab Cable Anchor Brackets |
Guys,
Dave will sell the Trim Tab Cable Anchor Bracket (replacement for the WD-415 that is supplied with the kit) for $15 a piece. I have installed these brackets on my Rv10 kit. Dave is an engineer and told me that these brackets are 3 times stronger than the steel weldment that Vans supplies in the kit. It also has more threads to grab the trim tab cable. It has a wider "footprint" than Vans weldment yet it still clears the Trim Tab cover plate doubler with no problem. 4 holes are pre drilled. Very easy to install. Made of 6061 aluminum.
If you want a set, please call Dave at 302-437-6087. He can answer all your questions.
Zack
#40512
rvbuilder(at)sausen.net Guest
Posted: Sun Jan 08, 2006 7:47 am Post subject: RV10 Trim Tab Cable Anchor Brackets |
Do the four holes match the original four holes or will we need new cover plates if already drilled?
Michael Sausen
-10 #352 Fuselage
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Joseph Czachorowski
Sent: Saturday, January 07, 2006 8:59 PM
To: RV10-List(at)matronics.com
Subject: RV10-List: RV10 Trim Tab Cable Anchor Brackets
carl.froehlich(at)cox.net Guest
Posted: Sun Jan 08, 2006 9:37 am Post subject: RV10 Trim Tab Cable Anchor Brackets |
I just got 4 for my project and a neighbors. Nice work.
Carl
RV-10 # 40528
RV-8A (220 hrs).
