Extended Tank Range
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Zenith640-List
Christian Tremblay
PostPosted: Thu Sep 18, 2008 7:12 am    Post subject: Extended Tank Range Reply with quote
Hi gang,
I ordered the Extended Tank Range (2 x 23 gal US) threw CanZaq Aviation (Canada), and I would say that I am more than happy Laughing by the QUALITY of the tanks (10/10). The thank had no waves deformation and they are accurate. Even with my best local welder, I cant find a better Job.
First good surprise, the plan specified 0.025 material in 6061-T6, and the thanks were in 0.032. Secondo, the tank are coming with all fittings from the tank to the firewall. I don't ordered the complete kit, only the tank with fitting. It come with tube vent, fuel quality cap, fuel quality selector, electronic sensor and a gascolator, 1 inch. cork, fuel line and so on. The inventory is completed, no missing pieces, conform to plan.
I will post photography later on the photo archive forum.
Conclusion : Its over my expectations and It's dont pay to do it yourself.
Tanks to Zenith and Mark Townson from CanZaq Aviation.
- The Matronics Zenith640-List Email Forum -
http://www.matronics.com/Navigator?Zenith640-List
Christian Tremblay - Montreal, Qc
A guy who build a CH640 from plan - SN0059
www.zodiac640.com
pilot4pay
PostPosted: Thu Sep 18, 2008 9:47 am    Post subject: Re: Extended Tank Range Reply with quote
I find it odd that they would have .025 spec'd in the plans and then make the tanks in .032. In a recent conversation with Tim, he told me they used .025 for tank construction.
Glad to hear you are happy with the product. .032 would definitely make for a stronger tank, and easier weld operation.
Still planning to build my own, since I bought .025 on Tim's recommendation that is what I'll use.
Craig Smith
CH640 builder
SN: 0078
"Just think how stupid the average person is,
and then realize that half of them are even stupider!"
--George Carlin
Christian Tremblay
PostPosted: Thu Sep 18, 2008 10:31 am    Post subject: Re: Extended Tank Range Reply with quote
May be It's because they are bigger than standard tanks they made it in 0.032.
www.zodiac640.com
pilot4pay
PostPosted: Thu Oct 16, 2008 7:11 am    Post subject: Re: Extended Tank Range Reply with quote
Chris, could you please take some photographs of the tanks? I'm particularly interested in the sides and back. Thanks.
If you don't care to post them here you can e-mail them directly to me. I think you have my e-mail address already.
Craig Smith
CH640 builder
SN: 0078
--George Carlin
Christian Tremblay
PostPosted: Fri Oct 17, 2008 4:20 pm    Post subject: Photo of Extended Tank Range Reply with quote
In attachement 6 photos of the tanks and all piece includes with the kit.
Christian
Close look to Gaz Selector, Gaz cap and Gascolator.
 Filesize:  432.79 KB
 Viewed:  1526 Time(s)
All piece supplied with the tank : from tank to Firewall - including all fitting needed
 Filesize:  437.08 KB
 Viewed:  1453 Time(s)
Botton of Right tank - Vent tube welded inside on top
 Filesize:  434.54 KB
Top of the Right tank
 Filesize:  427.37 KB
 Viewed:  1449 Time(s)
Inbord side of Right Tank
 Filesize:  402.39 KB
 Viewed:  1435 Time(s)
Left & Right tank
 Filesize:  403.01 KB
 Viewed:  1441 Time(s)
www.zodiac640.com
pilot4pay
PostPosted: Sat Oct 18, 2008 1:32 pm    Post subject: Extended Tank Range Reply with quote
Hey Chris, one more question, please. Is the top/nose/bottom and back skin
one continuous sheet of aluminum? That would make three pieces total for
shell construction.
C.S.
Craig Smith
CH640 builder
SN: 0078
--George Carlin
Christian Tremblay
PostPosted: Sun Oct 19, 2008 8:03 am    Post subject: Re: Extended Tank Range Reply with quote
Yes the bottom, up and back sides is a continuous form, one piece. You have also left and right side, this mean 3 pieces to weld. If you plan to do the tanks in 0.025, I suggest you an inside ribs with holes in bottom and top to let the gaz freely circulates. This inside rib will give more rigidness to the tank.
See you.
Christian
www.zodiac640.com
super58d
PostPosted: Wed Oct 22, 2008 3:21 am    Post subject: Re: Extended Tank Range Reply with quote
Hey Chris,
First off thanks for the posting the pics. They were great. I was wondering what type of fuel sending probes you were going to use. I want to install a flat panel like the Advanced flight systems one, and I'm not sure if it needs a specific type of fuel sending unit. I think the ones you have in your pictures are float type, not the capacitance type, right? Just wondering if you have done any research as to whether other types of sender units can be installed in these tanks.
Mark
s/n 094
My Build Site:
http://www.mykitlog.com/stephen363/
pilot4pay
PostPosted: Wed Oct 22, 2008 4:50 am    Post subject: Re: Extended Tank Range Reply with quote
Try the following link for just about everything you ever wanted to know about capacitive fuel senders. These guys make them right here in Michigan. I'll be using them in my aircraft.
http://airstuff.com/index.html
very educational website.
You'll want to find out for sure what your avionics needs before you order the probes. But you can order mounting flanges separately, that's what I have done, so I can procede with tank construction without having to decide on avionics installation.
Craig Smith
CH640 builder
SN: 0078
--George Carlin
super58d
PostPosted: Fri Oct 24, 2008 2:58 am    Post subject: Re: Extended Tank Range Reply with quote
Thanks Craig,
Very neat site. It'll take me awhile to got through all the info they have there though. Lot of good stuff! I really like the mini power panel too.
Mark
Mark
s/n 094
My Build Site:
pilot4pay
PostPosted: Mon Oct 27, 2008 10:12 am    Post subject: Re: Extended Tank Range Reply with quote
Chris, I have yet another question. From the photographs, I see that the fuel float assy. is not installed. I'm guessing that the small welded panel on the side is the base for installing the the float assy?
Craig Smith
CH640 builder
SN: 0078
--George Carlin
Christian Tremblay
PostPosted: Mon Oct 27, 2008 6:54 pm    Post subject: Re: Extended Tank Range Reply with quote
Hi Craig,
Your right, this small plate is for attaching the fuel sensor with 3/16 metal screw x 5/8 of an inch (24 tread). The hole was done with a 1 5/8 Dewalt hole drill cut off remover. This plate is done with a square piece (3 x 3 inches) with a 0.125 piece of 6061-T6 welded to the tank skin. See photographies attached.
Christian
 Filesize:  379.42 KB
 Viewed:  1303 Time(s)
 Filesize:  450.44 KB
 Viewed:  1361 Time(s)
www.zodiac640.com
Christian Tremblay
PostPosted: Mon Oct 27, 2008 7:02 pm    Post subject: Re: Extended Tank Range Reply with quote
Additional info:
Rectification it is not exactly metal screw that should be used, but metal bolt with cross head for tightening with a screw driver tool. You should do hole with tread with a left hand tap tool.
Christian
 Filesize:  444.42 KB
 Viewed:  1318 Time(s)
www.zodiac640.com
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Zenith640-List All times are GMT - 8 Hours
