vk3eka(at)bigpond.net.au Guest
Posted: Fri Oct 24, 2008 2:14 pm Post subject: Mechanical Fuel Pump |
Hi Guys,
I am rebuilding an O-200 for experimental use.
The engine I have doesn’t have a mechanical fuel pump or the eccentric on the cam to drive one. Do I need a different cam or does the eccentric fit in between the cam end and the vacuum pump drive?
Any other ideas would be good?
Cheers
Peter.
| | - The Matronics Continental-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
agustafson(at)chartermi.n Guest
Posted: Fri Oct 24, 2008 4:28 pm Post subject: Mechanical Fuel Pump |
Peter
I have the same engine in a Zenith 601 and I just used 2 Facet fuel pumps, one in each tank. It's a lot cheaper for sure. Do you even have the boss to mount a pump on. Mine did not.
Aaron
Posted: Fri Oct 24, 2008 4:46 pm Post subject: Mechanical Fuel Pump |
Aaron,
Thanks, I am also building a 601XL. The O-200 does have the place for a mechanical pump but nothing else. I have a copy of WW Corvair/601 book so may go with the double electric pump setup.
Peter
From: owner-continental-list-server(at)matronics.com [mailto:owner-continental-list-server(at)matronics.com] On Behalf Of Aaron Gustafson
Sent: Saturday, 25 October 2008 11:28 AM
To: continental-list(at)matronics.com
Subject: Re: Continental-List: Mechanical Fuel Pump
Peter
Aaron
