Nylaflow
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Glasair-List
MPPalmer(at)aol.com
PostPosted: Wed Oct 15, 2008 6:25 am    Post subject: Nylaflow Reply with quote
Hi Robin:
After numerous failures of the nylaflow at both the brakes (overheating) and at the master cylinders (due to movement), I finally switched to the Aeroquip TFE race quality, steel braid wrapped Teflon lined stuff that other's here in Phoenix are using. It's sold by Summit Racing.
http://store.summitracing.com/partdetail.asp?autofilter=1&part=AER%2DFCC0320&N=700+4294924496+4294821621+4294923289+4294906635+4294906583+115&autoview=sku
It was a bear opening up the existing conduit in the back of the landing gear struts to accept the larger diameter hose (I soldered a Dremel tool grinding head to welding rod and even then, I had to slice the conduit open) but haven't had a failure since. I wish I had done it when building.
Mike Palmer <><
BUY Indiana Jones and the Kingdom of the Crystal Skull on DVD today! (http://pr.atwola.com/promoclk/100000075x1209326865x1200539441/aol?redir=http://www.indianajones.com/site/index.html) [quote][b]
- The Matronics Glasair-List Email Forum -
http://www.matronics.com/Navigator?Glasair-List
Craymondw(at)aol.com
PostPosted: Wed Oct 15, 2008 9:51 am    Post subject: Nylaflow Reply with quote
I have well over a 1,000 hours on my brake lines and never had a failure. When I installed mine I formed a 360 loop before installing the line and I make sure the loop is out board of the fitting in the caliper. Also, when I land and I am on roll out, I deploy the flaps to 45% and hold back on the stick and hold full aleron into the wind ( trying to get all the paddles I can into the air) When I apply brakes, I first give them a quick stab. I find forming miniature "S" turns helps slow the plane down. Opening up the hatches on roll out really slows the plane down. I guess it works because I get well over 200 hours on a set of pads.
New MapQuest Local shows what's happening at your destination. Dining, Movies, Events, News & more. Try it out!
robin02(at)mindspring.com
Thanks Mike, this is just the information I am looking for. You might remember I am changing my gear to the Grove set up. While on this, I am putting the pressure recovery wheel pants on. I am looking forward to the results. I have done nothing to improve the speed in several years and hope this will be significant.
How is the healing coming? Robin
From: owner-glasair-list-server(at)matronics.com [mailto:owner-glasair-list-server(at)matronics.com] On Behalf Of MPPalmer(at)aol.com
Sent: Wednesday, October 15, 2008 10:25 AM
To: glasair-list(at)matronics.com
Subject: Re: Nylaflow
Hi Robin:
Mike Palmer <><
BUY Indiana Jones and the Kingdom of the Crystal Skull on DVD today! http://www.indianajones.com/site/index.html)
href="http://www.matronics.com/Navigator?Glasair-List">http://www.matronics.com/Navigator?Glasair-List
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Glasair-List All times are GMT - 8 Hours
