N1BZRich(at)AOL.COM Guest
Posted: Tue Oct 14, 2008 7:33 pm Post subject: Speeds vs. RPMs |
All,
Sometime within the last week or so I got a message directly to me asking some questions about actual speeds vs. RPMs at 2,500 feet. Unfortunately I deleted the message (not on purpose) and don't remember who sent it. However, I did get a chance to run a few numbers on today's flight and the specific results are below. So whoever asked the question, here is your answer:
N31BZ was at 2,500 feet MSL, density altitude was 3,880', with an OAT of 77 degrees F.
2850 rpm = 150 mph true airspeed and 142 mph indicated. fuel flow = 5.0 gph
2950 rpm = 156 mph true airspeed and 156 mph indicated. fuel flow = 5.6 gph
3050 rpm = 163 mph true airspeed and 153 mph indicated. fuel flow = 6.4 gph
And for "World Record" Earl, 150 mph = approximately 130 kts
� � � 156 mph = approximately 136 kts
� � � 163 mph = approximately 141 kts
Now some other thoughts:
-Of course, true airspeeds will go higher as altitude increases, but the person that asked the question wanted some figures at the lower altitudes - specifically 2,500 feet. When I am on a trip at 10,000 feet or so, I normally cruise at 165 to 170 true and burn about 6 gph up there. As I have mentioned before, my cross country technique is to set my fuel flow and accept what ever rpm and speed that gives me at the altitude I am at.
-For those of you that are still trying to decide if you want fuel flow, I highly recommend it. Not only for cross country work, but for use as a second "fuel quantity" system. Tell the EIS how much fuel you have when you fill up and the fuel flow then subtracts that much as you use it and you always know how much you have total (you must kind of guess which tank has how much of the total). This method, at least for me, is much more accurate than the fuel quantity gauges in the tanks.
-Your Lightnings (not EAB Lightnings that are set up to meet light sport requirements) should be a little faster once you get the proper prop installed and we all know that Nick is still working on that. For example the prototype runs about one or two mph faster than 31BZ the way both are currently equipped (gear leg farinings and Lightning style wheel pants), but we are waiting on a 62FK60 for both planes. The prototype currently has a prop that is marked as a 62FK58 but it measures closer to a 59 inch pitch. N31BZ is still running a 64ZK55. Now if Sensenich will just send us the two 62FK60s that have been on order for the past 20 years or so.
-In any case, other than the correct prop, the key to going fast is building your airplane light and straight, and attention to detail on the airframe (clean up mods, getting the fairings and pants on straight).
-Perhaps this info will also be helpful to "rimorbod" (mcpc(at)wp.pl (mcpc(at)wp.pl)) since no one really answered his question from about a week ago.
Blue Skies,
Buz
New MapQuest Local shows what's happening at your destination. Dining, Movies, Events, News & more. Try it out!
| - The Matronics Lightning-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Lightning-List |
info(at)flylightning.net Guest
Posted: Wed Oct 15, 2008 6:03 am Post subject: Speeds vs. RPMs |
Buz,
We have a 62 56 here for sport that we could of used for testing, actually 2 of them and I forgot that they were here, I think I am getting old and forgetful. Oh and we did get one of the 62 60s yesterday. We will start some testing with the 56 first since blanks put it on already and than we will get some numbers with the 60
nick
From: owner-lightning-list-server(at)matronics.com [mailto:owner-lightning-list-server(at)matronics.com] On Behalf Of N1BZRich(at)aol.com
Sent: Tuesday, October 14, 2008 10:33 PM
To: lightning-list(at)matronics.com
Subject: Speeds vs. RPMs
All,
Blue Skies,
Buz
Quote: | http://www.matronics.com/Navigator?Lightning-List | 0123456789
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum You cannot attach files in this forum You cannot download files in this forum
